    Ender 5 - CR-Touch on Duet Mini 3 5+
    Third-party add-ons
    • MightyRaithundefined
      MightyRaith
      I cannot for the life of me get the CR-Touch to work with my Duet Mini 3 5+ When the printer is turned on the probe does NOT self check but flashes red - Reset probe macro does reset the probe to a purple light.
      Using deployprobe.g causes it to revert to red flashing
      Once in a blue moon I am able to use the deploy and retract macros to move the probe but only for a few mins and then it goes back to flashing red.
      Ender 5 Pro
      RepRapFirmware 3.3
      Updated web controls 3.3
      Duet 3 Mini 5+
      Direct-Drive Extruder
      Wiring at probe
      Wiring at board end (Not my image but wires are in same order this was just better pic than I had taken)
      • Macgyverundefined
        Macgyver
        Bltouch/crtouch will not work with common ground both grounds must be on separate pins. I tried a similar configuration last year and feel your frustration.
        MightyRaithundefined 1 Reply Last reply Reply Quote 0
          MightyRaith @Macgyver
          @Macgyver How did you resolve that did you have to use the gnd pin on a nearby IO for the other earth?
          • Macgyverundefined
            Macgyver
            Yes correct, the black wire is not actually ground, the brown one is. The black wire (on factory bltouch units is actually a low digital. It's called ground but it's part of the pio.
            I just got a new phone and do not have the pic, I will look for my old post and put a link to it here.
            • Macgyverundefined
              Macgyver
              Here is the link to my origional problem
              Config and pics are there
              https://forum.duet3d.com/topic/24586/duet-2-with-duex-5-cannot-get-bltouch-to-function
                dc42 administrators @MightyRaith
                @MightyRaith my best guess is that you have a bad crimp connection in either the ground pin, the 5V pin or the control pin.
                Which firmware version are you using on the Duet 3 Mini? There was a startup timing issue that affected some BLTouch devices attached to Duet Maestro boards, which was fixed in a recent firmware version (3.4 AFAIR). It might possibly affect Duet 3 Mini too although we had no reports of that.
