    Colour DWC Header by printer
    Duet Web Control wishlist
    • CNCModellerundefined
      CNCModeller
      Hi All,
      Is there any way to change the colours of the DWC background or the header to make it cleared which machine I'm looking at?
      I'm now running 3 printers and a laser sometimes concurrently and TBH I've hit cancel on the wrong machine more than once!! When I was just running 2 machines I simply had one set to dark mode and one set to normal.
      Any constructive thoughts would be much appreciated!!!
      Many thanks
      Barry M
      Polar Duet3 Mini + 1HCL
      https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
      Wanhao D4S: Duet2
      https://forum.duet3d.com/post/296755
      K40 Laser, Duet2
      https://forum.duet3d.com/post/312082
      Wanhao D5S
      https://www.youtube.com/CNCModellerUK
      T3P3Tonyundefined MichaelKallnerundefined 2 Replies Last reply Reply Quote 2
      • T3P3Tonyundefined T3P3Tony moved this topic from Duet Web Control
      • T3P3Tonyundefined
        T3P3Tony administrators @CNCModeller
        @CNCModeller I have moved this here as it could be a nice setting to add to DWC configuration.
        www.duet3d.com
        • MichaelKallnerundefined
          MichaelKallner @CNCModeller
          @CNCModeller
          Hi, you can change the machine Name in config.g with the M550 P“machinename“
          This Name ist shown in the Top of the DWC.
          FDM Printer: 4x Tractus T3000 XXL Deltaprinter (Magnum+ Directdrive) / 2x Tractus T1250 Deltaprinter (E3D Supervolcano Bowden)
          1x SLA Ancycubic MonoX 6K
          CNCModellerundefined 1 Reply Last reply Reply Quote 0
            CNCModeller @MichaelKallner
            @MichaelKallner said in Colour DWC Header by printer:
            @CNCModeller
            Thanks @MichaelKallner I am aware of that, and my machines are all named differently, but it doesn't really make much of a difference when you're skipping between several machines running concurrently, it's very easy to make a mistake.
            Wanhao D4S: Duet2
            K40 Laser, Duet2
            Wanhao D5S
            MintyTreborundefined 1 Reply Last reply Reply Quote 0
            • MintyTreborundefined
              MintyTrebor @CNCModeller
              @CNCModeller I noticed your post whilst I was in the middle of an update for BtnCmd, so I quickly added an option in the plugin's global settings to allow you to change the top bar color - hope this helps until an official solution arises.
              NodeDSF - Native Node-Red integration with Duet boards.
              BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
              ReleaseMgr - Duet update info inside DWC.
              Repo
              CNCModellerundefined 1 Reply Last reply Reply Quote 3
                CNCModeller @MintyTrebor
                @MintyTrebor thanks that's great, I'll have a look next time I fire up the printers.
                Much appreciated 👍😎
                Cheers
                Barry M
                Wanhao D4S: Duet2
                K40 Laser, Duet2
                Wanhao D5S
