Big ask... Z probing
I was wondering if anyone would be prepared to give me some specific guidance on a method of detecting changes in tool length (on a CNC) as a step towards using multiple tools on a project.
Normally, I set up the X, Y and Z of the project using the "eyes and paper" method and set the working zero using the appropriate button on the DWC interface. I do intend to use something like the Carbide3D BitZero in the future, but that's a future project.
As I understand it, after the Work X, Y and Z zeroes have been set and I start the CNC machine on its journey, once the toolpath has completed and the tool has moved to a specific "safe" position (which I can set in the PP, without any difficulty), I'm assuming that, at this point, the X, Y and Z work zeroes are still "known" to the machine. So far, so good.
If I need to change the cutting bit for a subsequent toolpath to be cut on the same project, I would like to use a macro to automate the task of measuring the length of the cutting bit and adjusting the Z height (+ or -) accordingly.
I'm thinking I could use a switch like this at a fixed location on the baseboard, and connected to an appropriate i/o connector on my Duet3 MB6HC.
This is similar to the workflow my old Shapeoko used.
I have tried researching this on this forum and elsewhere, but translating anything I've found into my needs is where I stumble, as most refer to a printer, not a CNC.
Thanks
Wouldn't the procedure be exactly the same as homing z ? Your tool setting thingy becomes the z=0 switch and instead of going to what is usually the center of the build plate on a 3D printer, you go where the tool setter is located. The printer goes to the tool setter and slowly lowers the tool height until you connect with the tool setter. That will be your z0 position. Assuming the height of the tool setter is known, you can then reset z0 to the actual z0 position by subtracting the tool setter height from the current z0 and making that your new z0 position.
Just take the homez.g file from your system files, copy it, tweak it and save it as a macro and call it 'set tool zero' or something similar.
Of course you would also tweak your config.g file to have a second z home switch configured. See G30 in the gcode reference.Hopefully, with just tweaking existing files, it becomes manageable .....
@Nightowl I suggest you set up the switch as a Z probe. Create a macro that moves to max height, positions the tool over the switch, and uses G30 S-2 to probe and set the tool Z offset.
Thank you, @jens55
Technically it probably is, but I think I must be a bit slow on the uptake because the logic isn't working for me. I've got the process in my head, but it's just transposing that into my machine
@dc42 said in Big ask... Z probing:
I think that's what I have in my head, but perhaps I'm tying myself in knots overthinking it, but is it really that simple?
Would I need to set up the probe in the config.g file using the M558 command, like this:
; Z-Probe M558 P5 H5 F120 T500 ; enable Z probe, set dive height, probe speed and travel speed (Is the H5 value critical, in as much as the probe has to be a maximum of 5mm - in this case - above the switch, or do I need to take account of the travel distance within the switch too, please?)
And then, would the macro look something like this?
; Z-Probe Macro G91 G1 Z{max(move.axes[2].userPosition+5,move.axes[2].max-5)} F2400 ; move the Z axis to 5mm below Zmax G0 Xnnn Ynnn F2400 ; move XY above the switch G0 Znnn F150 ; Probe slowly G30 S-2 ; Where the magic happens? Once the probe sequence is complete, I would like to position the tool back to where it was when the macro was initiated - but with the cutting tool 5mm above the workpiece.
Alternatively, I could use the co-ordinates of the switch as the point at which the spindle goes, once the cut is complete. That way, all I would need to do is change the cutting tool, run the macro to adjust for the tool length and, when I run the subsequent cut, the spindle will move above the start point and the Z height will have been adjusted for the difference in tool length by the Z-Probe macro, yes?
@Nightowl said in Big ask... Z probing:
I think that first max should be a min, in case Z axis is already at max.
You will also need to use G31 to set the trigger height of the Z probe, normally in config.g after the M558 command.
You can use G60 to save the position before probing, and G0 with the R parameter to go back to that position or a related position.
