    DWC Doesn't show heater
    • dselaundefined
      dsela
      I'm running DUET 3 (3.4.4) and trying to assign 3 heaters to Tool 0.
      Only two heaters show up on the control panel (3 on the graph):
      If I try to comment out Heater 2 (PE-Lower) than Heater 1 (PE-Upper) does show up.
      Config.g:
      ; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.12 on Fri Aug 05 2022 12:05:46 GMT+0300 (Israel Daylight Time)
      G90                                          ; send absolute coordinates...
      M83                                          ; ...but relative extruder moves
      M550 P"K6"                                   ; set printer name
      G4 S2 ; wait for expansion boards to start
      M552 P192.168.2.3 S1                             ; enable network and acquire dynamic address via DHCP
      M586 P0 S1                                   ; enable HTTP
      M586 P1 S0                                   ; disable FTP
      M586 P2 S0                                   ; disable Telnet
      M569 P0.2 S0                                 ; physical drive 0.2 goes forwards
      M569 P0.0 S0                                 ; physical drive 0.0 goes forwards
      M569 P0.1 S1
      M569 P0.3 S0                                 ; physical drive 0.3 goes forwards
      M569 P40.0 S1 R0                            ; physical drive 0.4 goes forwards
      M569 P40.0 T20:20:20:20
      M584 X0.2 Y0.0:0.1 Z0.3 E40.0                  ; set drive mapping
      M350 X8 Y16 Z16 I1                                  ; configure microstepping with interpolation
      M92 X320.00 Y132.84 Z640.00 E420.00             ; set steps per mm
      M566 X30 Y200 Z30 E50.00            ; set maximum instantaneous speed changes (mm/min)
      M203 X180 Y1800 Z180 E120.00      ; set maximum speeds (mm/min)
      M201 X20.00 Y120.00 Z20.00 E25.00         ; set accelerations (mm/s^2)
      M906 X2500 Y4000 Z2500 I30              ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                      ; Set idle timeout
      M208 X0 Y0 Z0 S1                             ; set axis minima
      M208 X300 Y210 Z50 S0                        ; set axis maxima
      M574 X1 S1 P"io3.in"                         ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in
      M574 Y1 S1 P"io0.in"                         ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io2.in
      M574 Z1 S1 P"io4.in"                         ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin io3.in
      M558 P0 H0 F120 T1200                        ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20                     ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Block" ;
      M950 H0 C"out7" T0
      M307 H0 B0 S1.00
      M143 H0 S230
      M308 S1 P"temp1" Y"thermistor" T100000 B4956 C1.587780e-7 A"PE-Upper";
      M950 H1 C"out8" T1
      M307 H1 B0 S1.00
      M143 H1 S230
      M308 S2 P"temp2" Y"thermistor" T100000 B4956 C1.587780e-7 A"PE-Lower";
      M950 H2 C"out9" T2
      M307 H2 B0 S1.00
      M143 H2 S230
      ;M950 F0 C"out4" Q500                         ; create fan 0 on pin out4 and set its frequency
      ;M106 P0 S0 H-1                               ; set fan 0 value. Thermostatic control is turned off
      ;M950 F1 C"out5" Q500                         ; create fan 1 on pin out5 and set its frequency
      ;M106 P1 S1 H1 T45                            ; set fan 1 value. Thermostatic control is turned on
      M563 P0 D0 H0:2                          ; define tool 0
      G10 P0 X0 Y0 Z0                              ; set tool 0 axis offsets
      G10 P0 R0 S0                                 ; set initial tool 0 active and standby temperatures to 0C
      T0
      Thanks
      • chrishammundefined
        chrishamm administrators @dsela
        @dsela try
        M563 P0 D0 H0:1:2
        instead of
        M563 P0 D0 H0:2
        Duet software engineer
        • dselaundefined
          dsela
          Works - Thanks!
          • dc42undefined dc42 marked this topic as a question
