    Retrofit Hardware
    753
    • Lexanundefined
      Lexan
      Hi @ll
      i'd like to retrofit an older Printer, with XY Closed Loop Motors with own drivers and Z Normal Motors, 2 Extruders and 1 Servo to change the height of the current running hotend.
      The Hardware i selected so far is the following:
      1x Duet 3 6HC
      2x 1LC
      1x Paneldue 7"
      1x Duet 3 Tool Distribution Board
      now my question is, can i control the Servo motor with 1 of the 1LC Toolboards or do i need to carrie the wire from the 6HC all the way to the servo?
      TIA
      Lexan
      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @Lexan
        @Lexan depending on how much current the servo wants, yes
        you also can't run external drivers from the 6HC so you'll want to look at the 1XD https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Expansion_1XD
        Lexanundefined 1 Reply Last reply Reply Quote 0
          dc42 administrators @Lexan
          @Lexan how much current do the Z motors need? If it's not a lot then the Duet 3 Mini would cost you less than the 6HC.
          • Lexanundefined
            Lexan @jay_s_uk
            @jay_s_uk wait, i cant controll an external Driver like an HSS57 with the 6HC directly ?
            @dc42 if i found the correct datasheet, it should be around 15mA, the mini wouldnt fit based on 2A limit drivers
              @Lexan you said they were "normal" Z motors, so I assumed they were bipolar stepper motors without drivers. Is that correct? If so then they need much more than 15mA.
              • Lexanundefined
                Lexan @dc42
                @dc42 no i ment 2 steppers, controlled each by one 1lc toolboard, and the servo that lift the current extruder is something similar like this https://www.sunfounder.com/products/25kg-high-torque-servo
                • Lexanundefined
                  Lexan
                  ah okay i get the issue, so this is an extra servo just for the hotend unit.
                  my plan for the z axis stepper drivers is to use the TMC5160 from the 6HC board
                  jay_s_ukundefined Lexanundefined 2 Replies Last reply Reply Quote 0
                    jay_s_uk @Lexan
                    @Lexan correct. You can't drive an external driver using a 6HC
                    • Lexanundefined
                      Lexan @Lexan
                      @Lexan ah i see my fault, the 6XD can, right ?
                      Edit: just seen that make's no sense for my situation.
                        jay_s_uk @Lexan
                        @Lexan yes, the 6XD can.
                        In the duet 3 family it's pretty much yet the 6XD or 1XD boards for each motor with an external driver
                        • Lexanundefined
                          Lexan @jay_s_uk
                          @jay_s_uk okay this fix the problem that i didnt seen comming, but wont answer my problem i see comming 😄
                          can i control the 25 kg servo via the 1lc toolboard ?
                          and if yes, wich port can i use?
                            jay_s_uk @Lexan
                            @Lexan do you have a part number for it?
                            • Lexanundefined
                              Lexan @jay_s_uk
                              @jay_s_uk said in Retrofit Hardware:
                              i will check that out tmrw, just play with the idea to use a 3hc board instead the 2x 1lc
                              • Lexanundefined
                                Lexan @Lexan
                                @Lexan should be a DSSERVO DS3225
                                  jay_s_uk @Lexan
                                  @Lexan said in Retrofit Hardware:
                                  DSSERVO DS3225
                                  I would say not. seems like it can pull up to 1.9A which is too much for a toolboard
                                  • Lexanundefined
                                    Lexan @Lexan
                                    @Lexan any recommends how to controll this one instead ?
                                    i think ~2A will be also too much for the 6hc
                                      jay_s_uk @Lexan
                                      @Lexan it may well be. Best to just use a step down converter.
                                      The control can still be from the toolboard or 6HC.
                                      • Lexanundefined
                                        Lexan @Lexan
                                        @Lexan okay but then the control could also be from a toolboard, right ?
                                        the way to the hotend is about 4 meters, so i would like to take the cables as short as possible
                                          jay_s_uk @Lexan
                                          @Lexan yes to controlling from the toolboard. you'd either have to run a separate 5v cable or mount a stepdown converter on the toolhead
