    Calibrate the Z probe trigger height
    671
    • Karimundefined
      Karim
      ; Z probes
      M558 P5 C"^zprobe.in" H5 F300 T6000            ; set Z probe type to switch and the dive height + speeds
      G31 P500 X0 Y0 Z.18                         ; set Z probe trigger value, offset and trigger height
      M557 X0:282 Y0:275 S40                        ; define mesh grid
      Hey guys I am trying to get my z-offset lower to the bed, Once you have the nozzle touching the bed, send command G92 Z0 to tell the firmware that the head is at Z=0, I then Jog the head up 10mm and Send command G30 S-1, in the config.g file I Set the Z parameter in the G31 to the value I got from G30 S-1.
      After I restart the duet I still get the same offset that I got before (The Nozzle is above the bed.
        Tell us how you are homing. Share your homeall.g and homez.g or any other macros used in the process.
        Karimundefined 1 Reply Last reply Reply Quote 0
        • Karimundefined
          Karim @Phaedrux
          @Phaedrux here you go. No macro used.
          https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
          ; Configuration file for Duet WiFi (firmware version 3.3)
          ; generated by RepRapFirmware Configuration Tool v3.3.13 on Fri Oct 14 2022 18:23:20 GMT-0400 (Eastern Daylight Time)
          M111 S0                                            ; Debugging off
          G21                                                ; Work in millimetres
          M550 P"Voron"                                      ; set printer name
          M669 K1                                            ; select CoreXY mode
          M564 S1 H1                                         ; Forbid axis movements when not homed
          ; --- Z Drive map ---
          ;     _______
          ;    | 6 | 7 |
          ;    | 5 | 8 |
          ;      front
          ; (looking at the printer from the top)
          ; Drive directions
          M569 P0 S0 ; A
          M569 P1 S0 ; B
          M569 P3 S1 ; Extruder
          M569 P5 S0 ; Z1
          M569 P6 S1 ; Z2
          M569 P7 S0 ; Z3
          M569 P8 S1 ; Z4
          M584 X0 Y1 Z5:6:7:8 E3                            ; Motor mapping and steps per mm
          M350 X16 Y16 Z16 E16 I1                           ; configure microstepping with interpolation
          M92 X80.00 Y80.00 Z400.00 E562.00                 ; set steps per mm
          M566 X900.00 Y900.00 Z60.00 E120.00               ; set maximum instantaneous speed changes (mm/min)
          M203 X60000.00 Y60000.00 Z18000.00 E1200.00       ; set maximum speeds (mm/min)
          M201 X6000.00 Y6000.00 Z4000.00 E250.00           ; set accelerations (mm/s^2)
          ; Drive currents
          M906 X1500 Y1500 Z1200 E400 I30                    ; set motor currents (mA) and motor idle factor in per cent
          M84 S10                                            ; Set idle timeout
          M574 X2 S1 P"^xstop"                              ; Xmax endstop on hall effect board
          M574 Y2 S1 P"^ystop"                              ; Ymax endstop on hall effect board
          M574 Z1 S2                                       ; configure Z-probe endstop for low end on Z
          ; Axis travel limits
          M208 X0 Y0 Z0 S1               ; Set axis minima
          M208 X312 Y325 Z275 S0          ; Set axis maxima
          ; Z probes
          G31 P500 X0 Y0 Z0                        ; set Z probe trigger value, offset and trigger height
          ; Bed leveling
          M671 X-65:-65:365:365 Y0:395:395:0 S20      ; Define Z belts locations (Front_Left, Back_Left, Back_Right, Front_Right)
          ;Bed (Keenovo 750w 120v)
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
          M307 H0 R0.490 K0.247:0.000 D1.97 E1.35 S1.00 B0   ; enable bang-bang mode for the bed heater and set PWM limit
          ;E3d Revo Voron)
          M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8       ; configure sensor 1 as thermistor on pin e0temp
          M307 H1 R4.091 K0.614:0.000 D1.92 E1.35 S1.00 B0   ; disable bang-bang mode for heater  and set PWM limit
          M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
          M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
          M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
          M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
          M950 F2 C"duex.fan3" Q500                          ; create fan 2 on pin duex.fan3 and set its frequency
          M106 P2 S1 H1 T205                                  ; set fan 2 value. Thermostatic control is turned on
          M950 F3 C"duex.fan4" Q500                          ; create fan 3 on pin duex.fan4 and set its frequency
          M106 P3 S1 H1 T205                                 ; set fan 3 value. Thermostatic control is turned on
          M950 F2 C"fan2" Q500                               ; create fan 2 on pin fan2 and set its frequency
          M106 P2 S1 H1 T45                                  ; set fan 2 value. Thermostatic control is turned on
          ; LEDs
          M950 H2 C"nil" ; free up e2_heat pin
          M950 F3 C"duex.e2_heat"
          M106 P3 S255 B0 H-1 C"Top Lights"
          ;Neopixel
          M150 X4
          M150 W255 P255
          G10 P0 X0 Y0 Z0                                   ; set tool 0 axis offsets
          M501                                ; load config-override.g
          T0                                  ; select tool 0                                              ; load saved parameters from non-volatile memory
          M143 H0 S110
          M143 H1 S300
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v3.3.14 on Sat Oct 29 2022 11:20:15 GMT-0400 (Eastern Daylight Time)
          G1 H2 Z5 F6000          ; lift Z relative to current position
          G1 H1 X355 Y355 F6000 ; move quickly to X or Y endstop and stop there (first pass)
          G1 H1 X355             ; home X axis
          G1 H1 Y355             ; home Y axis
          G1 X-5 Y-5 F6000          ; go back a few mm
          G1 H1 X355 F360        ; move slowly to X axis endstop once more (second pass)
          G1 H1 Y355             ; then move slowly to Y axis endstop
          G1 X140 Y150 F6000     ; go Center of bed
          G30                     ; home Z by probing the bed
          G32
          ; homez.g
          ; called to home the Z axis
          ; generated by RepRapFirmware Configuration Tool v3.3.14 on Sat Oct 29 2022 11:08:05 GMT-0400 (Eastern Daylight Time)
          G1 X140 Y150 F6000 ; go to first probe point
          ; bed.g
          ; generated by RepRapFirmware Configuration Tool v2 on Mon Dec 10 2018 01:47:39 GMT+0000 (GMT)
          ;G28 Z ; home Z
          M671 S20
          G1 F20000 X0 Y0 Z10
          G30 P0 X0 Y0 Z-99999
          G1 F20000 X0 Y275 Z10
          G30 P1 X0 Y275 Z-99999
          G1 F20000 X282 Y275 Z10
          G30 P2 X282 Y275 Z-99999
          G1 F20000 X282 Y0 Z10
          G30 P3 X282 Y0 Z-99999 S4
          G1 F9000 X140 Y150 Z150
            At the end of your homeall you call G32, which runs bed.g which is doing tilt and roll correction. You should add a G30 at the center of the bed after you've done that to re-establish the Z0 position incase it has changed with the tilt correction.
            • Karimundefined
              Karim @Phaedrux
              @Phaedrux Hey I am not following you, are you saying add G30 at then end of home.g after G32.
              How do I get G30 to go at the center of the bed. Like this.
              ; homeall.g
              G32
              G30 P4 X140 Y150 Z-99999
                G90; absolute positioning
                Add that to your bed.g right above the last line.
                • Karimundefined
                  Karim @Phaedrux
                  @Phaedrux Thank, I can get a good first layer now.
                  Here is another question. How do I get the probe to go three times around the bed.
                  ; bed.g
                  ;G28 Z ; home Z
                  M671 S20
                  G1 F20000 X0 Y0 Z10
                  • A Former User?
                    A Former User @Karim
                    @Karim
                    You want to probe each point multiple times? Check out the M558 "A" and "N" parameters... A is maximum number of probes per point and N is the tolerance
                    https://docs.duet3d.com/en/User_manual/Reference/Gcodes
                    change this line in you config
                    to
                    M558 P5 C"^zprobe.in" H5 F300 T6000  A3 S0.02          ; set Z probe type to switch and the dive height + speeds
                    This change will probe each point up to three times or only twice if the deviation between the two probings is less than 0.02
                      If you mean doing 3 iterations of the leveling process, the easiest way is to simply duplicate the commands the number of times you want it to do.
                      ; bed.g
                      ;G28 Z ; home Z
                      M671 S20
                      G1 F20000 X0 Y0 Z10
                      ;first
                      ;second
                      G1 F20000 X0 Y0 Z10
                      ;third
                      G1 F20000 X0 Y0 Z10
                      • Karimundefined
                        Karim @Phaedrux
                        @Phaedrux ok, Also how do you slow the z probing in each of the three passes.
                        I saw someone has this.
                        ; Probe the bed at 4 points, x3 for more precision
                        M558 K0 H10 F1200 ; increase the depth range, gets the gantry mostly level immediately
                        M98 P"/sys/bed.g"
                        M558 K0 H4 F240   ; reduce depth range, probe slower for better repeatability
                        M98 P"/sys/bed.g"
                        M558 K0 H1 F60    ; reduce depth range, probe slower for better repeatability
                        M98 P"/sys/bed.g"
                          That could work too, or just add the M558 commands to your bed.g between the iterations.
                          • Karimundefined
                            Karim @Phaedrux
                            @Phaedrux Hey how about this. Do I have to add M671 S20 to bed.g
                            ;bed_probe_points
                            G30 K0 P0 X0 Y0 Z-99999            ; probe point 0 near a leadscrew
                            G30 K0 P1 X0 Y275 Z-99999          ; probe point 1 near a leadscrew
                            G30 K0 P2 X282 Y275 Z-99999        ; probe point 2 near a leadscrew
                            G30 K0 P3 X282 Y0 Z-99999 S4       ;probe point 3 near a leadscrew and calibrate 4 motors
                            ; bed.g
                            ; Called to align the gantry to the bed plane via G32
                            M561                    ; Clear any bed transform
                            M84 E3                  ; Turn off noisy Extruder motor
                            G28                     ; Home all axes
                            M98 P"/sys/bed_probe_points.g"
                              Phaedrux Moderator @Karim
                              @Karim said in Calibrate the Z probe trigger height:
                              No that should probably stay in config.g. Only call it if you intend to change it.
                              • Karimundefined
                                Karim @Phaedrux
                                @Phaedrux ok what do this means.
                                The K parameter is applicable to all G30 commands. It is the Z probe number, default 0. It is not remembered between G30 commands, it always defaults to 0.
                                For example I use it here.
                                M558 K0 H4 F240
                                  Do you actually have multiple probes? If not, just remove the K0 entirely from all commands.
                                  • Karimundefined
                                    Karim @Phaedrux
                                    @Phaedrux like this.
                                    ;bed_probe_points
                                    G30 P0 X0 Y0 Z-99999            ; probe point 0 near a leadscrew
                                    G30 P1 X0 Y275 Z-99999          ; probe point 1 near a leadscrew
                                    G30 P2 X282 Y275 Z-99999        ; probe point 2 near a leadscrew
                                    G30 P3 X282 Y0 Z-99999 S4       ;probe point 3 near a leadscrew and calibrate 4 motors
                                    also the K0 in here too.
                                    ; bed.g
                                    G28                     ; Home all axes
                                      Yes but how many probe devices do you actually have?
                                      • Karimundefined
                                        Karim @Phaedrux
                                        @Phaedrux one z probe, no z end stop switch
                                          Then you don't need K0 anywhere.
                                          • Karimundefined
                                            Karim @Phaedrux
                                            @Phaedrux Got it working, Thank You.
