    JohnSL's FSR on a dute Wifi 3.4.4 not working
    532
    • eddygaraundefined
      eddygara
      I always hesitated upgrading this particular machines firm ware due to fear of all of this not working, and so it is to be true. I upgraded firmware from 2.0 to 3.4.4 and everything stopped working.
      I have the machine running fine now, though i can not for the life of me get my FSR to calibrate my printer.
      can someone please help, before i rip out all my hair.
      Z-probe reads a constant 1000 and triggers before even reaching the bed.
      When i home i also get all of these error messages.
      G28
      Error: in file macro line 7 column 8: G1: expected number after 'X'
      Error: G0/G1: target position not reachable from current position
      here is my config file.
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.14 on Fri Nov 11 2022 17:32:14 GMT-0500 (Eastern Standard Time)
      M550 P"My Printer" ; set printer name
      M665 R143.461 L290 B140 H300.74 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S1 ; physical drive 0 goes backwards
      M569 P1 S1 ; physical drive 1 goes backwards
      M569 P2 S1 ; physical drive 2 goes backwards
      M92 X160.00 Y160.00 Z160.00 E833.16 ; set steps per mm
      M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
      M906 X1200 Y1200 Z1200 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 Z-1 S1 ; set minimum Z
      M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
      M558 P5 C"!zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
      G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 R138 S20 ; define mesh grid
      M307 H0 R0.137 K0.229:0.000 D24.81 E1.35 S1.00 B0 ; disable bang-bang mode for the bed heater and set PWM limit
      T0 ; select first tool
      here is my homing file
      ; homedelta.g
      ; generated by RepRapFirmware Configuration Tool v3.2.0 on Sun Jan 03 2021 21:41:01 GMT-0500 (Eastern Standard Time)
      G91 ; relative positioning
      ;*** Slow homing has been configured. Change F180 to F1800 below when your configuration is working
      G1 H1 XH300.74 YH300.74 ZH300.74 F4000 ; move all towers to the high end stopping at the endstops (first pass)
      G1 H2 X-5 Y-5 Z-5 F2000 ; go down a few mm
      ;*** Slow homing has been configured. Change F180 to F360 below when your configuration is working
      G1 H1 X200 Y200 Z200 F3600 ; move all towers up once more (second pass)
      G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
      G90 ; absolute positioning
      G1 X0 Y0 F6000 ; move X+Y to the centre
      eddygaraundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • eddygaraundefined
        eddygara @eddygara
        I have already tried running this command in all of these variants with the same problem
        M558 P5 C"!zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds Didn't work
        M558 P5 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds Didn't work
        M558 P8 C"!zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds Didn't work
        M558 P8 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds Didn't work
        eddygaraundefined dc42undefined 2 Replies Last reply Reply Quote 0
        • eddygaraundefined
          eddygara @eddygara
          here is where the pins are attached alt text
          • Phaedruxundefined Phaedrux referenced this topic
            Phaedrux Moderator @eddygara
            @eddygara said in JohnSL's FSR on a dute Wifi 3.4.4 not working:
            The endstops are set to the wrong end for a delta. They should be high end endstops. Change the X1 Y1 Z1 to X2 Y2 Z2
            This line is nonsense 🙂 Try G1 H1 X300 Y300 Z300 F4000
            eddygaraundefined 1 Reply Last reply Reply Quote 0
              The pins of what?
              • eddygaraundefined
                eddygara @Phaedrux
                @Phaedrux this the connection pins to the fsr sensor board.
                • eddygaraundefined
                  eddygara @Phaedrux
                  @Phaedrux said in JohnSL's FSR on a dute Wifi 3.4.4 not working:
                  Will this fix the probing issue of the FSR? Or is this to fix my homing command?
                  Thanks for the help!
                    dc42 administrators @eddygara
                    @eddygara for the JohnSL board connected to Duet 2 I think you may need:
                    M558 P8 C"!^zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
                    The correct setting will show a Z probe reading of 0 normally. For the Duet 2 you need the ^ character in the pin name. When the bed is tapped so that the LED on the JohnSL board flashes, DWC may or may not briefly show a Z prove reading of 1000.
                    • eddygaraundefined
                      eddygara @dc42
                      @dc42 said in JohnSL's FSR on a dute Wifi 3.4.4 not working:
                      Putting in that new change did no help. The board no longer reads 1000 on the z probe, but it will not activate when pressed on the bed.
                        The photo shows a connection to an endstop, but your config is trying to use the zprobe input. Where is the actual signal wire connected?
                        • eddygaraundefined
                          eddygara @Phaedrux
                          @Phaedrux It funny you say that, my previous firmware had me connecting to the endtop,
                          Ive changed the position looking though some old post and found the correct connection that's working fine now.
                          My final issue is homing.
                          When i home now, instead of doing one pass up to the end stops, and moving back down for a 2nd pass. it just stops after the 1st pass directly on the end stops. then it doubles my z height, from 300, 600.
                          and i get this error.
                          G28
                          When i did as you said and changed my end stop config, the printer would not home or moves the
                          axis at all,
                            What changes have you made to the config and homing file? Can you post homedelta.g and config.g as they are now?
                            Have you tested that the motor directions are correct?
                            It may be helpful to review these delta documents
                            https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuration_linear_delta
                            https://docs.duet3d.com/en/User_manual/Tuning/Delta_calibration
                            eddygaraundefined 2 Replies Last reply Reply Quote 0
                            • eddygaraundefined
                              eddygara @Phaedrux
                              @Phaedrux
                              config
                              M665 R145.094 L290 B140 H290.716 ; Set delta radius, diagonal rod length, printable radius and homed height
                              M666 X1.57 Y-1.97 Z0.40, tilt X0.72% Y-1.10% ; put your endstop adjustments here, or let auto calibration find them
                              M558 P8 C"!^zprobe.in" H30 F1000 T6000 ; set Z probe type to switch and the dive height + speeds
                              G31 P500 X0 Y0 Z-0.18 ; set Z probe trigger value, offset and trigger height
                              M557 R100 S20 ; define mesh grid
                              homeing
                              ; homedelta.g
                              G1 H1 X300 Y300 Z300 F4000 ; move all towers to the high end stopping at the endstops (first pass)
                              G1 H2 X-15 Y-15 Z-15 F2000 ; go down a few mm
                              G1 H1 X20 Y20 Z20 F3600 ; move all towers up once more (second pass)
                              G1 Z-25 F6000 ; move down a few mm so that the nozzle can be centred
                              • eddygaraundefined
                                eddygara @eddygara
                                @eddygara
                                As of right now the printer does work as intended minus the headache of the homing.
                                If i home anywhere on the bed after performing an action.
                                for example if i run a red calibration, then home. the printer will think im at my home height starting from where the printer head is at. doubling the effective home height.
                                i hope you understand.
                                • eddygaraundefined
                                  eddygara @Phaedrux
                                  @Phaedrux Got it working now! it was my fault for not reading your directions currently!
                                  Thanks to the both of yous!
