JohnSL's FSR on a dute Wifi 3.4.4 not working
I always hesitated upgrading this particular machines firm ware due to fear of all of this not working, and so it is to be true. I upgraded firmware from 2.0 to 3.4.4 and everything stopped working.
I have the machine running fine now, though i can not for the life of me get my FSR to calibrate my printer.
can someone please help, before i rip out all my hair.
Z-probe reads a constant 1000 and triggers before even reaching the bed.
When i home i also get all of these error messages.
G28
Error: in file macro line 7 column 8: G1: expected number after 'X'
Error: G0/G1: target position not reachable from current positionhere is my config file.
; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.14 on Fri Nov 11 2022 17:32:14 GMT-0500 (Eastern Standard Time); General preferences
M550 P"My Printer" ; set printer name
M665 R143.461 L290 B140 H300.74 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S1 ; physical drive 0 goes backwards
M569 P1 S1 ; physical drive 1 goes backwards
M569 P2 S1 ; physical drive 2 goes backwards
M92 X160.00 Y160.00 Z160.00 E833.16 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1200 Y1200 Z1200 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z-1 S1 ; set minimum Z; Endstops
M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop; Z-Probe
M558 P5 C"!zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 R138 S20 ; define mesh grid; Heaters
M307 H0 R0.137 K0.229:0.000 D24.81 E1.35 S1.00 B0 ; disable bang-bang mode for the bed heater and set PWM limit
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
T0 ; select first tool
here is my homing file
; homedelta.g
; generated by RepRapFirmware Configuration Tool v3.2.0 on Sun Jan 03 2021 21:41:01 GMT-0500 (Eastern Standard Time)
G91 ; relative positioning
;*** Slow homing has been configured. Change F180 to F1800 below when your configuration is working
G1 H1 XH300.74 YH300.74 ZH300.74 F4000 ; move all towers to the high end stopping at the endstops (first pass)
G1 H2 X-5 Y-5 Z-5 F2000 ; go down a few mm
;*** Slow homing has been configured. Change F180 to F360 below when your configuration is working
G1 H1 X200 Y200 Z200 F3600 ; move all towers up once more (second pass)
G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
G90 ; absolute positioning
G1 X0 Y0 F6000 ; move X+Y to the centre
I have already tried running this command in all of these variants with the same problem
M558 P5 C"!zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds Didn't work
M558 P5 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds Didn't work
M558 P8 C"!zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds Didn't work
M558 P8 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds Didn't work
here is where the pins are attached
undefined Phaedrux locked this topic
A single thread is sufficient.
https://forum.duet3d.com/topic/30407/johnsl-s-fsr-on-a-dute-wifi-3-4-4-not-working
