    Can't connect to duet Web just says connecting
    Firmware installation
    325
    • Willnkundefined
      Willnk
      Trying to connect to Duet web control, but is stuck connecting and at the bottom of my screen it says incompatible firmware version, it happened when updating firmware and it failed halfway through
        jay_s_uk @Willnk
        @Willnk can you connect via USB and see what firmware version is reported by M115?
        Willnkundefined 1 Reply Last reply Reply Quote 0
        • Willnkundefined
          Willnk @jay_s_uk
            jay_s_uk @Willnk
            @Willnk wow, that's out of date. It may be quicker to just bossa the board up to 3.4.4
            Willnkundefined 2 Replies Last reply Reply Quote 0
            • Willnkundefined
              Willnk @jay_s_uk
              @jay_s_uk yep but I can't acess the duet Web to do so
              • Willnkundefined
                Willnk @jay_s_uk
                @jay_s_uk or can you update firmware from the sd?
                  jay_s_uk @Willnk
                  @Willnk you can update from the SD card. You'll have to put the files in the sys folder and use M997
                  If you can't get that to work use bossa https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#all-other-duet-boards
                  Willnkundefined 4 Replies Last reply Reply Quote 0
                  • Willnkundefined
                    Willnk @jay_s_uk
                    @jay_s_uk thanks
                    • Willnkundefined
                      Willnk @jay_s_uk
                      @jay_s_uk so just download the 3.4.4 firmware onto the sd in the sys folder as a zip and when I use m997 it will sort it out correctly?
                      • Willnkundefined
                        Willnk @jay_s_uk
                        This post is deleted!
                        • Willnkundefined
                          Willnk @jay_s_uk
                          @jay_s_uk nvm everything works your a life saver
                          • ckeithleyundefined
                            ckeithley
                            How were you able to resolve the problem? I am dealing with the exact same thing after mistakenly trying to upgrade 2.05 directly to 3.4.4. I've literally tried everything I can think of with no success.
                              Phaedrux Moderator @ckeithley
                              @ckeithley said in Can't connect to duet Web just says connecting:
                              You can use Bossa software to directly flash the latest firmware to the board.
                              https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#fallback-procedure-2
                              You would also need to manually update the DWC files on the SD card with the matching version for the firmware.
