    Getting phase errors for extruder motor
    344
    • bwenigundefined
      bwenig
      Hello, I just wired up my duet to a new printer and have successfully homed x,y,z axes. I am now trying to test my extruder motor. I am running a macro with
      T0
      G1 E10 F60
      When I run this macro, I get the following error from the console:
      Warning: Driver 3 warning: phase A may be disconnected, phase B may be disconnected
      It will repeat this error about 20 times in the span of a second and there is no movement by the extruder motor. I have checked and replaced all of the wiring and connections. Not sure what the issue might be?
      Thanks, Ben
        Try mapping the extruder to another driver and test again. If it works as expected, you may have a damaged driver chip. If it doesn't work on that driver either but that driver works with other motors, then it's likely a wiring issue.
        It would also help to see your full config.g and the results of M122.
        bwenigundefined 1 Reply Last reply Reply Quote 0
        • bwenigundefined
          bwenig @Phaedrux
          @Phaedrux So I tried another motor on the same driver and got the same error. I mapped the extruder to another driver and got the same error. Tried a new motor on the new driver and same error.
          Here is my config.g file:
          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Apr 06 2021 11:31:03 GMT-0400 (Eastern Daylight Time)
          G90                                     ; send absolute coordinates...
          M83                                     ; ...but relative extruder moves
          M550 P"HartingsLabFlashforge"                      ; set printer name
          M555 P1
          M552 S2 ; Turn network on in access point mode
          M569 P0 S0                              ; physical drive 0 goes forwards
          M569 P1 S1                              ; physical drive 1 goes forwards
          M569 P2 S1                              ; physical drive 2 goes forwards
          M569 P3 S1                              ; EXTRUDER physical drive 3 goes forwards
          M584 X0 Y1 Z2 E3                        ; set drive mapping
          M350 X64 Y64 Z16 E16 I1                 ; configure microstepping with interpolation
          ;M92 X376.48 Y376.48 Z400.00 E15360.00       ; set steps per mm
          ;M92 X378.37 Y380.41 Z403.83 E15360.00       ; set steps per mm
          M92 X377.46 Y380.41 Z403.83 E15360.00       ; set steps per mm
          M566 X180.00 Y180.00 Z60.00 E6.00     ; set maximum instantaneous speed changes (mm/min)
          M203 X1800.00 Y1800.00 Z600.00 E60.00 ; set maximum speeds (mm/min)
          M201 X150.00 Y150.00 Z150.00 E15.00     ; set accelerations (mm/s^2)
          ;M566 X600.00 Y600.00 Z60.00 E6.00     ;FAST set maximum instantaneous speed changes (mm/min)
          ;M203 X6000.00 Y6000.00 Z600.00 E60.00 ;FAST set maximum speeds (mm/min)
          ;M201 X600.00 Y600.00 Z150.00 E15.00   ;FAST set accelerations (mm/s^2)
          M906 X550 Y550 Z450 E1100 I70           ; set motor currents (mA) and motor idle factor in per cent
          M84 S30                                 ; Set idle timeout
          M208 X0 Y0 Z0 S1                        ; set axis minima
          M208 X105 Y150 Z50 S0                  ; set axis maxima
          M574 X2 S1 P"!xstop"                     ; configure active-high endstop for high end on X via pin xstop
          M574 Y2 S1 P"!ystop"                     ; configure active-high endstop for high end on Y via pin ystop
          M574 Z2 S1 P"!zstop"                     ; configure active-high endstop for high end on Z via pin zstop
          M140 H-1                                ; disable heated bed (overrides default heater mapping)
          M563 P0 D0                        ; define tool 0
          G10 P0 X0 Y0 Z0                         ; set tool 0 axis offsets
          G10 P0 R0 S0                            ; set initial tool 0 active and standby temperatures to 0C
          My M122:
          m122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.4 (2022-10-20 16:17:41) running on Duet WiFi 1.02 or later
          Board ID: 0JD2M-9F8TA-GJ4TD-6J1D6-3SD6M-16PQ6
          Used output buffers: 1 of 26 (26 max)
          Static ram: 23860
          Dynamic ram: 74320 of which 0 recycled
          Never used RAM 13828, free system stack 140 words
          Tasks: NETWORK(ready,15.4%,257) HEAT(notifyWait,0.0%,388) Move(notifyWait,0.0%,322) MAIN(running,83.6%,438) IDLE(ready,1.0%,30), total 100.0%
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:03:12 ago, cause: software
          Last software reset at 2022-11-13 15:51, reason: User, GCodes spinning, available RAM 13828, slot 0
          Error status: 0x04
          Step timer max interval 0
          MCU temperature: min 29.7, current 30.1, max 30.8
          Supply voltage: min 24.4, current 24.7, max 25.1, under voltage events: 0, over voltage events: 0, power good: yes
          Events: 3709 queued, 3709 completed
          Driver 0: standstill, SG min n/a
          Driver 1: standstill, SG min n/a
          Driver 2: standstill, SG min n/a
          Driver 3: standstill, SG min 0
          Driver 4: standstill, SG min n/a
          Driver 5:
          Driver 6:
          Driver 7:
          Driver 8:
          Driver 9:
          Driver 10:
          Driver 11:
          Date/time: 2022-11-13 15:55:05
          Slowest loop: 7.67ms; fastest: 0.18ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 6.1ms, write time 0.0ms, max retries 0
          DMs created 83, segments created 3, maxWait 49999ms, bed compensation in use: none, comp offset 0.000
          === MainDDARing ===
          Scheduled moves 2, completed 2, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1
          === AuxDDARing ===
          Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty
          === Network ===
          Slowest loop: 13.35ms; fastest: 0.00ms
          Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
          HTTP sessions: 1 of 8
          = WiFi =
          Network state is active
          WiFi module is providing access point
          WiFi firmware version 1.27
          WiFi MAC address a6:e5:7c:03:da:75
          WiFi Vcc 3.36, reset reason Power up
          WiFi flash size 2097152, free heap 24896
          WiFi IP address 192.168.0.1
          Connected clients 1
          Clock register 00002002
          bwenigundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
          • bwenigundefined
            bwenig @bwenig
            I also get this error when nothing is plugged into the drivers
              Phaedrux Moderator @bwenig
              @bwenig said in Getting phase errors for extruder motor:
              So it follows the motor and the driver?
              Did the new motor you tried on the new driver use the same wiring?
              So you have two drivers now that are not working?
              So which drivers are the ones having a problem?
              Have you tried one of the drivers that is currently working on one of the existing axis like X?
              E15360.00
              This is a very high steps per mm. What kind of extruder is this?
              Can you post some photos of the driver chips?
              • bwenigundefined
                bwenig @Phaedrux
                @Phaedrux
                Yes, it follows the motor and driver.
                Yes I used the same wiring, and tried switching the A and B as well/
                So now I have two drivers not working: E0 and E1.
                I am hesitant to try the motor on a working axis! But I will test it now.
                I am using a Replistruder. I got the config.g file from a research paper.
                Here are some pics of the board:
                Phaedruxundefined bwenigundefined 3 Replies Last reply Reply Quote 0
                  You should use new wiring.
                  • bwenigundefined
                    bwenig @bwenig
                    So plugging the extruder motor into the x axis results in the same error, but I heard some clicking out of the motor, it tried to move a little bit.
                    I plugged the x driver back into the x motor and luckily everything still works fine.
                      I don't know what that is, but 16000 steps per mm is insanely high. How fast are you trying to command the extruder to move?
                      • bwenigundefined
                        bwenig @Phaedrux
                        @Phaedrux My extruder has very fine movement, so I think 160000 steps might not be too bad? Here's a video of me moving it manually: alt text
                          Well it may limit speed.
                          • bwenigundefined
                            bwenig @Phaedrux
                            @Phaedrux Should I try a much smaller E value? Not sure what else I could try to get these drivers to cooperate
                              Do the drivers work if you move the X/Y axis to them and remap?
                              • bwenigundefined
                                bwenig @Phaedrux
                                @Phaedrux No, they throw the same phase errors
                                  And if you put the X/Y motors on the drivers you were using for the extruder and remap do they work there?
