    Expansion Breakout Board to Duet Wifi
    • r123undefined
      r123
      Already have a Duex connected to the large connector of Duet Wifi.
      Is it possible/OK to wire intelligently an Expansion Breakout Board (to get differential driver outputs) to the smaller connector on the Duex Wifi (Steppers 10 and 11, next to the Panel Due connector)??
      • r123undefined
        r123
        hey guys, I'm still stuck on this. It's not clear from the Documentation (https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/Duet_Expansion_Breakout_Board_ ) what the expansion breakout board uses by way of Input. It's not clear what the chips are on the board.
        DO they just use pins like +5v, +3v, STEP, DIR... that I can take from the small connectof (steppers 10/11 etc) above? Or do they require the full-on MISO/MOSI stuff?
        I feel the need, the need for speed!
          jay_s_uk @r123
          @r123 have a look at the schematic here https://github.com/Duet3D/Duet-2-Hardware/blob/master/Duet_Expansion/Expansion_Breakoutv1.1/ExpBreakoutv1.1_Schematic.pdf
          theres no SPI etc is just enable, step (pulse) and direction
          r123undefined 1 Reply Last reply Reply Quote 1
          • r123undefined
            r123 @jay_s_uk
            @jay_s_uk Awesome. So it' just 5v/GND and the STEP/DIR inputs. Worst case scenario I can hook up with a handful of female-female breadboard connectors from the Stepper10/11 connector on the Duet Wifi.
            Thanks a LOT!
