    Stutters during arcs & circles
    • Jareryundefined
      Jarery
      Recent upgrades to my printer, but same board and firmware as previous.
      Slicer is Superslicer Version: 2.4.58.5, which I used prior also with no issues.
      Doing parts now I get blobs and zits on my part, even in vase mode
      I can watch it in vase mode with no layer changes or retractions and it pauses/stutters whenever it's doing arcs or circles.
      Issue is very similar to https://youtu.be/Hvw3DrVAeTA
      edit :
      https://youtu.be/ZM1MYbsC5Aw
      this is the same problem, and zits on parts, except I have power recovery off so his solution does not work.
      I also reduced resolution to 0.5mm in slicer, so that round egg shape is now low poly looking, but same problem,
      Is there a setting with RRF that helps this situation or is this purely slicer based ?
      System:
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.3+ (2022-10-06)
      Duet WiFi Server Version: 1.27
      Edit 2: Turns out to be related to daemon.g
      When I did my upgrades I added neopixels to printhead which change based on different input status.
      Have not figured out just what in the macros was causing the pauses.
      Daemon was only 2 lines G4 1 , and a P98 to run the led macro.
      jay_s_ukundefined deckingmanundefined Phaedruxundefined 3 Replies Last reply Reply Quote 0
        jay_s_uk @Jarery
        @Jarery probably the G4 S1 causing a 1 second pause
        Jareryundefined 1 Reply Last reply Reply Quote 0
        • deckingmanundefined
          deckingman @Jarery
          @Jarery It's probably as @jay_s_uk says, but there may be other issues which could only be guessed at unless you provide more information such as your configuration files and slicer settings.
          • Jareryundefined
            Jarery @jay_s_uk
            @jay_s_uk
            Probably, so I just removed the daemon.g completely and its running fine.
            When I get time I'll try to find why the G4 S1 is causing a pause instead of just reloading macro, its also recommended in the documentation to have such a command.
            dc42undefined 1 Reply Last reply Reply Quote 1
              Phaedrux Moderator @Jarery
              @Jarery said in Stutters during arcs & circles:
              The documentation is more specific.
              https://docs.duet3d.com/en/User_manual/Reference/Gcode_meta_commands#daemong
              It is recommended to use a while loop inside the daemon.g file if you are using it to prevent the firmware having to open it every 10 seconds. E.g if you want a shorter update time then put a while loop inside the daemon.g with G4 S1 in it for 1 second repeats.
              If you have just 2 lines to pause and turn on the LEDs that will be executed every 10 seconds. You're missing the while loop.
              Is daemon.g the best place for your LED macro?
                dc42 administrators @Jarery
                @Jarery driving Neopixels from Duet 2 requires motion to be paused while the data is sent to the Neopixels, because their timing requirements are strict, so step pulses cannot be generated at the same time.
                Duet 3 main boards have a dedicated output for LED strips so that motion does not need to be interrupted.
