    Duet2 WiFi frequently disconnects when Paneldue 7i is connected
    PanelDue
    104
    • edsped
      edsped last edited by edsped
      When I connect the Paneldue 7i to my Duet2 WiFi unit the WiFi connection frequently disconnects. This happens primarily when I first start a print and the printer starts homing and running a MBL. I'll still get occasional disconnects once printing has started but not like the every few seconds when everything is starting.
      If I disconnect the paneldue WiFi is solid as a rock.
      The paneldue and the duet2 wifi are both on the latest firmware release.
      Any suggestions?
        Can you show us the wiring?
        Are you using the 4 wire or ribbon cable?
        Does the cabling run near any stepper cables?
        Can you show some photos of the soldering on the wifi module?
        edsped 1 Reply Last reply Reply Quote 0
        • edsped
          edsped @Phaedrux last edited by
          Image of the errors. Connected via 4 pin cable pictures of wiring to follow.
            Can you send M122 when connected to wifi and copy and paste the results here?
            • edsped
              edsped @edsped last edited by
              @edsped
              M122 without duet connected, mid print
              Derp
              Status
              Printing
              Mode: FFF
              Tool Position
              X
              126.6
              Y
              174.0
              Z
              52.80
              U
              0.0
              Extruder Drives
              Drive 0
              391.5
              Drive 1
              17248.9
              Drive 2
              279.9
              Drive 3
              262.9
              Speeds
              Requested Speed
              80.0 mm/s
              Top Speed
              52.2 mm/s
              Sensors
              Vin
              24.3 V
              MCU Temperature
              35.4 °C
              Z-Probe
              0
              Tools
              Extra
              Control Heaters
              Tool Heater Current Active Standby
              Amy
              T0 - Load Filament Heater 1
              standby 22.0 °C
              Betty
              T1 - Load Filament Heater 2
              active 205.0 °C
              Chloe
              T2 - Load Filament Heater 3
              standby 22.9 °C
              Daisy
              T3 - Load Filament Heater 4
              standby 22.3 °C
              Bed Heater 0
              active 60.3 °C
              Temperature Chart
              11/19/2022, 11:27:52 AM m122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.4 (2022-10-20 16:17:41) running on Duet WiFi 1.02 or later + DueX5
              Board ID: 08DLM-996RU-N85S4-7J9FA-3S86K-1BABN
              Used output buffers: 1 of 26 (26 max)
              Static ram: 23860
              Dynamic ram: 78684 of which 12 recycled
              Never used RAM 8396, free system stack 98 words
              Tasks: NETWORK(notifyWait,25.0%,199) HEAT(notifyWait,0.1%,308) Move(notifyWait,2.7%,282) DUEX(notifyWait,0.0%,24) MAIN(running,71.6%,421) IDLE(ready,0.6%,30), total 100.0%
              Owned mutexes: WiFi(NETWORK)
              Last reset 04:33:49 ago, cause: power up
              Last software reset at 2022-11-02 22:03, reason: User, GCodes spinning, available RAM 9940, slot 1
              Error status: 0x04
              Aux0 errors 0,0,0
              Step timer max interval 0
              MCU temperature: min 34.6, current 35.3, max 35.9
              Supply voltage: min 24.2, current 24.4, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
              Events: 0 queued, 0 completed
              Driver 0: ok, SG min 0
              Driver 1: ok, SG min 0
              Driver 2: standstill, SG min n/a
              Driver 3: standstill, SG min n/a
              Driver 4: standstill, SG min n/a
              Driver 5: standstill, SG min n/a
              Driver 6: standstill, SG min 0
              Driver 7: standstill, SG min 0
              Driver 8: standstill, SG min 0
              Driver 9: ok, SG min 0
              Driver 10:
              Driver 11:
              Date/time: 2022-11-19 11:27:58
              Slowest loop: 25.60ms; fastest: 0.20ms
              === Storage ===
              Free file entries: 8
              SD card longest read time 4.1ms, write time 3.8ms, max retries 0
              DMs created 83, segments created 47, maxWait 542ms, bed compensation in use: mesh, comp offset 0.000
              === MainDDARing ===
              Scheduled moves 136346, completed 136321, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
              === AuxDDARing ===
              Heater 0 is on, I-accum = 0.2
              Heater 2 is on, I-accum = 0.3
              Segments left: 1
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is doing "G1 X173.706 Y125.667 E.02351" in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              Daemon is idle in state(s) 0
              Code queue is empty
              === DueX ===
              Read count 0, 0.00 reads/min
              === Network ===
              Slowest loop: 99.93ms; fastest: 0.07ms
              Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
              HTTP sessions: 2 of 8
              = WiFi =
              Network state is active
              Failed messages: pending 0, notready 0, noresp 2
              WiFi firmware version 1.27
              WiFi MAC address f4:cf:a2:6e:7e:56
              WiFi Vcc 3.42, reset reason Turned on by main processor
              WiFi flash size 4194304, free heap 22968
              WiFi IP address 192.168.1.238
              WiFi signal strength -42dBm, mode 802.11n, reconnections 0, sleep mode modem
              Clock register 00002002
              11/19/2022, 11:27:35 AM Connected to 192.168.1.238
              • edsped
                @edsped
                Did the no no and plugged it in mid print... With paneldue plugged in, meant to say without paneldue plugged in above.
                Derp
                Status
                Printing
                Mode: FFF
                Tool Position
                X
                127.7
                Y
                134.4
                Z
                53.80
                U
                0.0
                Extruder Drives
                Drive 0
                391.5
                Drive 1
                17366.2
                Drive 2
                279.9
                Drive 3
                262.9
                Speeds
                Requested Speed
                40.0 mm/s
                Top Speed
                40.0 mm/s
                Sensors
                Vin
                24.5 V
                MCU Temperature
                35.5 °C
                Z-Probe
                0
                Tools
                Extra
                Control Heaters
                Amy
                standby 22.0 °C
                Betty
                active 204.9 °C
                Chloe
                standby 22.9 °C
                Daisy
                standby 22.3 °C
                Bed Heater 0
                active 60.0 °C
                Temperature Chart
                11/19/2022, 11:30:02 AM m122
                Static ram: 23860
                Tasks: NETWORK(ready,14.9%,199) HEAT(notifyWait,0.1%,308) Move(notifyWait,2.7%,282) DUEX(notifyWait,0.0%,24) MAIN(running,82.2%,421) IDLE(ready,0.2%,30), total 100.0%
                Owned mutexes:
                Last reset 04:35:58 ago, cause: power up
                Error status: 0x04
                Aux0 errors 0,0,2
                MCU temperature: min 34.8, current 35.7, max 36.2
                Supply voltage: min 24.2, current 24.5, max 24.8, under voltage events: 0, over voltage events: 0, power good: yes
                Driver 1: stalled, SG min 0
                Driver 10:
                Driver 11:
                Date/time: 2022-11-19 11:30:07
                Slowest loop: 49.63ms; fastest: 0.20ms
                === Storage ===
                SD card longest read time 12.1ms, write time 0.0ms, max retries 0
                DMs created 83, segments created 47, maxWait 540ms, bed compensation in use: mesh, comp offset 0.000
                === MainDDARing ===
                Scheduled moves 138222, completed 138182, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                === AuxDDARing ===
                Segments left: 1
                File is doing "G1 X172.344 Y136.439 E.02028" in state(s) 0
                Code queue is empty
                === DueX ===
                === Network ===
                Slowest loop: 99.85ms; fastest: 0.07ms
                = WiFi =
                Failed messages: pending 0, notready 0, noresp 4
                • edsped
                  @edsped
                  Connectors and solder joint
                  https://imgur.com/MTTXe9Y
                  On a side note, I've been running this setup for a couple of years now and issue seems to have popped up in the past couple of months. At first I thought the wifi unit was faulty.
                  • edsped
                    @edsped
                    https://imgur.com/7zawTmY
                      I mean the soldering around the wifi module itself.
                      • edsped
                        @edsped
                        Doh!!! Will have to do later as I don't want to try to rotate the printer mid print as it's pretty heavy. That being said if I disconnect the paneldue the disconnect issues go away. I've run for weeks without the paneldue without a single disconnect.
                        • edsped
                          as soon as the paneldue is connected the disconnects start up again.
                            dc42 administrators @edsped last edited by
                            @edsped it could be that the enclosure that you have mounted the PanelDue in is pressing the touch screen and sending continuous commands. Please check that is not the cause, for example by loosening the mounting screws.
                            Another possibility is that the PanelDue cable is picking up a lot of interference, for example from an adjacent stepper motor cable. However, that seems unlikely if the problem occurs mostly at startup when the motors have (I presume) not been energised yet.
                            edsped 2 Replies Last reply Reply Quote 0
                            • edsped
                              edsped @dc42 last edited by
                              I took the case off so the Paneldue is now sitting bare on a pile of napkins and am still getting the WiFi drops. I also switched from the 4 wire to a ribbon cable and the WiFi drops persist.
                              All that being said the drops pretty much only occur during G32. Once the print starts the connection stays solid. Not sure if it makes a difference but the consol on the paneldue doesn't show any issues. And disconnecting the paneldue eliminates the WiFi drops completely.
                              • edsped
                                As can be seen below, no disconnects once bed is leveled. I'm not going to go too crazy on this as I'm not sure how long it's been happening or if it's even worth chasing at this point as it's more of an annoyance and doesn't affect printing.
                                  What's in your bed.g? What kind of probe is it?
                                  • edsped
                                    edsped @Phaedrux last edited by edsped
                                    @Phaedrux
                                    It's an omron switch, (Jubilee Printer)
                                    I tried commenting out M558 as an experiment and it had no effect.
                                    I'm not overly concerned and as far as I know it may have been happening for the past couple of years and I just never noticed but I don't believe that was the case.
                                    M290 R0 S0 ; Reset baby stepping
                                    M561 ; Disable any Mesh Bed Compensation
                                    G91 ; Switch to relative positioning to drop the bed
                                    G1 Z3 F700 ; Drop Bed 3mm
                                    G90 ; Return to absolute positioning
                                    G1 X150 Y150 F18000 ; Move to the center of the bed
                                    M558 H3 A3 F100 T20000 ; Set the probing speed
                                    G30
                                    G30 P0 X290 Y290 Z-99999 ; probe near front left leadscrew
                                    G30 P1 X10 Y290 Z-99999 ; probe near front right leadscrew
                                    G30 P2 X152.5 Y10 Z-99999 S3 ; probe near back leadscrew and calibrate 3 motors
                                    G1 X150 Y150 F18000 ;Move probe to center of bed
                                    M558 H3 A3 F100 ; Set the probing speed
                                    G30 ; Set Z = 0
                                    G1 X0 Y0 Z4 F18000 ;Move probe home
                                      Just to test a theory, since it seems to only be a problem during the bed.g file, and it contains a bunch of probing moves, can you create a macro that has a similar amount of z axis moves and see if it can trigger the wifi issue?
                                      That would indicate some noise being picked up from the Z steppers. Perhaps shielding or twisting/braiding the cables would help there.
                                      • edsped
                                        @Phaedrux
                                        Will do but probably Friday before I give it a go as I feel like I'm in the Griswold house at the moment.
                                          @edsped As you have a DueX5 connected, one possibility is that a wire connected to an endstop input or a GPIO pin on the DueX5 is picking up noise. Whenever the state of a DueX input changes, an interrupt is generated and a task is activated to read the status change, and if this happens very frequently then it can starve the CPU. Are you using any inputs to the DueX5?
