    No heated bed activation?
    • create.at.hwbdesign.comundefined
      I'm setting-up a IDEX system and started to test it. For the heated bed on out0 is not possible to activate in my current config.g set-up.
      Can you tell me what I'm doing wrong?
      Config.g
      ; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.14 on Sat Nov 19 2022 22:42:29 GMT+0100 (Midden-Europese standaardtijd)
      M550 P"IDEX_JW" ; set printer name
      M552 P192.???.???.141 S1 ; enable network and set IP address
      M553 P255.255.255.0 ; set netmask
      M554 P192.???.???.254 ; set gateway
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0.1 S1 ; physical drive 0.1 goes forwards
      M569 P0.2 S0 ; physical drive 0.2 goes forwards
      M569 P0.3 S0 ; physical drive 0.3 goes forwards
      M569 P0.4 S1 ; physical drive 0.4 goes forwards
      M569 P0.5 S1 ; physical drive 0.5 goes forwards
      M584 X0.0 Y0.1 Z0.2 U0.3 E0.4:0.5 ; set drive mapping
      M350 X16 Y16 Z16 U16 E16:16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 U80.00 E:420.00:420.00 ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 U900.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 U6000.00:1200.00:1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 U500.00 E250.00:250.00 ; set accelerations (mm/s^2)
      M906 X1800 Y1800 Z2800 U1800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S45 ; Set idle timeout
      M208 X0 Y0 Z0 U0 S1 ; set axis minima
      M208 X305 Y210 Z200 U-305 S0 ; set axis maxima
      M574 X1 S3 ; configure sensorless endstop for low end on X
      M574 Y1 S3 ; configure sensorless endstop for low end on Y
      M574 U1 S3 ; configure sensorless endstop for low end on U
      M574 Z1 S1 P"io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin io2.in
      M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20 ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" A"Bed" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M308 S1 P"temp1" Y"thermistor" A"Extruder 1" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
      M143 H1 S305 ; set temperature limit for heater 1 to 280C
      M308 S2 P"temp2" Y"thermistor" A"Extruder 2" T100000 B4138 ; configure sensor 2 as thermistor on pin temp2
      M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2
      M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
      M143 H2 S305 ; set temperature limit for heater 2 to 280C
      M308 S3 P"temp3" Y"thermistor" A"Chamber" T100000 B4138 ; configure sensor 3 as thermistor on pin temp3
      M950 H3 C"out3" T3 ; create chamber heater output on out3 and map it to sensor 3
      M307 H3 B1 S1.00 ; enable bang-bang mode for the chamber heater and set PWM limit
      M141 H3 ; map chamber to heater 3
      M143 H3 S100 ; set temperature limit for heater 3 to 100C
      M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
      M106 P0 S0 H0 T45 ; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
      M950 F2 C"out6" Q500 ; create fan 2 on pin out6 and set its frequency
      M106 P2 S1 H2 T45 ; set fan 2 value. Thermostatic control is turned on
      M950 F3 C"out7" Q500 ; create fan 3 on pin out7 and set its frequency
      M106 P3 S1 H3 T45 ; set fan 3 value. Thermostatic control is turned on
      M563 P1 D1 H2 F0 ; define tool 1
      G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
      G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
      Joep
        What exactly is happening when you try and enable the bed?
        Have you wired input power for the out0 terminals?
        create.at.hwbdesign.comundefined 1 Reply Last reply Reply Quote 0
          create.at.hwbdesign.com @Phaedrux
          @Phaedrux
          Thanks for your reply.
          Yes, it's connected to OUT0 output second next to the power input.
          plus and minus correctly connected to the solid-state relay.
          Joep
            Yes, but do you have VIN connected to Out0-input?
            The Duet 3 Mainboard 6HC has a separate OUT0 Power in, which allows for a separate PSU (12V-36V, can be different to VIN voltage) to supply the OUT0 high current output (e.g for a large bed heater). If this is not required, VIN power must be applied to both the POWER IN and the OUT0 POWER IN terminals for OUT 0 to be powered.
              @Phaedrux
              Thanks, I will try and let you know.
                create.at.hwbdesign.com @create.at.hwbdesign.com
                @create-at-hwbdesign-com
                Thanks a lot, you gave me the solution for this mistake of me.
