    HOWTO Configure Z axis sensorless homing in homey.g file?
    Firmware installation
    868
    • NO1NOKAOundefined
      NO1NOKAO
      First of all, I have complicated the sensorless homing file of both X and Y axis. Fortunately, they all work. However, when I configure the Z axis homing file the same way that I configured the XY axis, it can't get the signal that the current of motors have changed when Z-axis arrived at the boundary.
      I would appreciate your help very much.
      The following is my config.g file and homez.g file;
      By the way, my control board is duet2 wifi ,rrf 3.3
      ;config.g
      ;Axis Limit
      M208 X-126:125 Y-92.3:50 Z125:-1 U-200:200 V-12000:12000
                                                          ; Centre of the rotating bed is set to origin 0,0
      M564 H0								; allow unhomed movement
      ; Endstops for each Axis
      M574 X1 S3				                 ; Set endstops controlled by motor load detection
      M574 Y1 S3                               ; Set endstops controlled by motor load detection
      M574 Z2 S4                               ; configure sensorless endstop for high end on Z (Detected by two motors)
      ; Stallgaurd Sensitivy
      M915 X S3 F0 H400 R1		                ; Set X axis Sensitivity
      M915 Y S3 F0 H400 R1		                ; Set y axis Sensitivity
      M915 Z S3 F0 H400 R1		                ; Set z axis Sensitivity
      ; homeZ.g
      ; 用于归零Z轴
      M400                        ; Wait for current moves to finish
      M913 X50 Y50:50                ; drop motor current to 50%
      M400
      G91                         ; relative positioning
      G1 H2 Y100 F10000           ; move away Y axis
      G1 H1 Z110 F12000           ; move quickly to Z axis endstop and stop there (first pass)
      G1 H2 Z-5 F12000            ; go back 5 mm
      G1 H2 Z-115 F6000           ; move Z axis to the mid
      G90                         ; absolute positioning
      M400
      M913 X100 Y100:100              ; return current to 100%
      M400
        dc42 administrators @NO1NOKAO
        @NO1NOKAO what type of Z axis do you have? If it's driven by a leadscrew then it won't be easy to get sensorless homing working, because of the force multiplication provided by the leadscrew.
        However, I note that you have used M913 to drop the Z and Y motor currents in homez.g, whereas for sensorless homing of the Z axis you need to drop the Z motor current. Likewise when you use M913 to restore the motor current later on.
        • NO1NOKAOundefined
          NO1NOKAO
          @dc42 It's really driven by a leadscrew. I'm developing a five-axis dispensing machine based on Prusa i3 just like FreddieHong did. And I have dropped the Z motor current to 35%,but luck didn't appear. Just like what you said the force provided by leadscrew makes it difficult to get sensorless homing.
            Can you post your full config.g and homing files?
            NO1NOKAOundefined 1 Reply Last reply Reply Quote 0
            • NO1NOKAOundefined
              NO1NOKAO @Phaedrux
              @Phaedrux
              config.g file
              ;Duet WiFi(固件版本3.3)的配置文件
              ; 用于启动时由固件执行
              ; 由RepRapFirmware配置工具生成 版本V3.3.10 时间 Tue Nov 01 2022 15:02:12 GMT+0800 (中国标准时间)
              G90                                ; Send absolute coordinates...
              M83                                ; ...but relative extruder moves
              M550 P"Y"                          ; Set machine name
              M669 K0 X1:0:0:0:0 Y0:-1:0:0:0 Z0:0:1:0:0 U0:0:0:1:0 V0:0:0:0:1;Kinematics Profile for 5-axis (cartesian)
              ; 网络
              M551 P"123456"                     ; set password
              M552 S1                            ; Enable network
              M586 P0 S1                         ; Enable HTTP
              M586 P1 S0                         ; Disable FTP
              M586 P2 S0                         ; Disable Telnet
              M587 S"A204_printer_04" P"junhua.zhao.04"  ;Set the Wi-Fi account and password
              ; Drive Mappings
              M569 P0 S1                         ; Drive 0 goes backward: X Axis
              M569 P1 S1                         ;Drive 1 goes backwards: Y Axis
              M569 P2 S1                         ; Drive 2 goes backwards: Z Axis
              M569 P3 S1                         ;Drive 3 goes forwards: U轴
              M569 P4 S1                         ; Drive 4 goes forwards: V轴
              M584 X0 Y1 Z2 U3 V4                ; My Driver Mapping
              ;Microstepping
              M350 X16 Y16 Z16 U16 V16 I1        ; Configure microstepping with interpolation
              M92 X100.00 Y100.00 Z400.00 U26.667 V35.556          ; Set steps per mm and steps per degree
              ;Speed
              M566 X480.00 Y480.00 Z24.00 E270.00 U480.00 V480.00 P1        ; Set maximum instantaneous speed changes (mm/min)
              M203 X12000.00 Y12000.00 Z750.00 E1500.00 U5000.00 V12000.00     ; Set maximum speeds (mm/min)
              M201 X1000.00 Y1000.00 Z1000.00 E1000.00 U1000.00 V1000.00       ; Set accelerations (mm/s^2)
              M906 X620.00 Y620.00 Z560.00 E700.00 U1300.00 V1300.00 I10           ; Set motor currents (mA) and motor idle factor in percent
              M84 S30                            ; Set idle timeout
              ; Axis Limit
              M208 X-125:126   Y-92.3:50  Z125:-1 U-200:200 V-12000:12000                   ; Centre of the rotating bed is set to origin 0,0
              M564 H0;                           ;allow unhomed movement
              M574 X1 S3                         ;Set endstops controlled by motor load detection
              M574 Y1 S3                         ;Set endstops controlled by motor load detection
              M574 Z2 S4                         ;configure sensorless endstop for high end on Z (Detected by two motors)
              M915 Z S3 F0 H400 R1		       ;Set z axis Sensitivity
              ; Z-Probe (manual)
              M558 P0 H15 F120 T6000             ; disable Z probe but set dive height, probe speed and travel speed
              ; Heatbed Heaters and Thermistor Bed
              M140 H-1                           ;Disable heated bed
              ;Tool
              M950 P0 C"Fan0" Q250				; creat tool P0
              homz.g file
              ; homeZ.g
              M913 Z50:50                ; drop motor current to 50%
              M400
              G1 H2 Z-5 F12000            ; go back a few mm
              M400
              M913 Z100:100              ; return current to 100%
              M400
                How many Z motors do you have?
                Your M574 command is using Z2 S4, for multiple motors, and your M913 command in your homing file has Z50:50 for two motors but your M584 command in the config.g file indicates you only have a single Z motor defined.
                The Z moves in your homing file have speeds far beyond the Z axis speed limits you have set in M203 in config.g as well.
                • gloomyandyundefined
                  gloomyandy @NO1NOKAO
                  @NO1NOKAO I don't think your current setting for Z is correct, you have:
                  But from the docs for M913: https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m913-set-motor-percentage-of-normal-current
                  "Example: If you have two motors on your Z axis, physically connected to Z and E0 stepper drivers, configured with M584 Z2:3, set M913 Z50, not M913 Z50:50"
                  NO1NOKAOundefined 1 Reply Last reply Reply Quote 2
                  • NO1NOKAOundefined
                    NO1NOKAO @gloomyandy
                    @gloomyandy Thanks for your help, both of the Z motors are wired to Drive2 as shown below.
                    And does that mean that I also need to rewrite the Z50:50 into Z50?
                    • NO1NOKAOundefined
                      NO1NOKAO
                      This post is deleted!
                      • NO1NOKAOundefined
                        NO1NOKAO @Phaedrux
                        @Phaedrux
                        I have two Z motors, and both of them are connected to Drive2.
                        Does that mean the command M584 X0 Y1 Z2 U3 V4 is wrong?And what do I need to change?
                        For the Z axis driven by leadscrew, what's the best speed for it?12000 or just lower than 1000?
                        And I‘m grateful for your help.
                          If both motors are wired to the same driver they are in effect just a single motor and this will make the stall detection even less likely to work.
                          If you have a free driver available you should move one of the Z motors to that driver, then you can likely get stall detection homing working as you have configured, but since you have a U and V axis I don't think that's an option for you.
                          Are endstops not an option?
                          NO1NOKAOundefined 1 Reply Last reply Reply Quote 1
                          • NO1NOKAOundefined
                            NO1NOKAO @Phaedrux
                            @Phaedrux Thanks buddy, I also have a duex5 panel and I also think endstop is a more convenient option. But if I choose endstop, I need to redesign the structure. So,I'll make a try first to wire the motors to different drivers and if plan A fails, the endstop will be the last way.
                              If you have a duex, then you have some extra drivers to use, so you may be able to get stall detection working. I would suggest keeping the Z axis on the mainboard and moving perhaps the U and V to the Duex.
                              This would also let you use automatic tilt correction.
                              https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_auto_levelling
                              • NO1NOKAOundefined
                                NO1NOKAO @Phaedrux
                                @Phaedrux I have tried to wire Z motors to different drivers(2 and 3), unfortunatly, the Z sensorless homing seems still failed. The following is my config.g file and homez.g file. If nothing is wrong, it is definitly the right time to take the endstop in consideration.
                                My config.g file
                                ; network
                                ; Drive Mappings
                                M569 P0 S1                         ; Drive 0 goes forwards: X Axis
                                M569 P1 S1                         ; Drive 1 goes forwards: Y Axis
                                M569 P2 S1                         ; Drive 2 goes forwards: Z1 motor
                                M569 P3 S1                         ; Drive 3 goes forwards: Z2 motor
                                M569 P4 S1                         ; Drive 4 goes forwards: U Axis
                                M569 P5 S0                         ; Drive 5 goes backwards: V Axis
                                M584 X0 Y1 Z2:3 U4 V5                ; My Driver Mapping
                                ;Microstepping
                                ;Speed
                                M566 X480.00 Y480.00 Z24.00 U480.00 V480.00 P1        ; Set maximum instantaneous speed changes (mm/min)
                                M203 X12000.00 Y12000.00 Z750.00 U5000.00 V12000.00     ;  Set maximum speeds (mm/min)
                                M201 X1000.00 Y1000.00 Z1000.00 U1000.00 V1000.00       ; Set accelerations (mm/s^2)
                                M906 X620.00 Y620.00 Z560.00 U1300.00 V1300.00 I10           ; Set motor currents (mA) and motor idle factor in percent
                                ; Axis Limit
                                ; Z-Probe (manual)
                                M140 H-1                           ; Disable heated bed
                                ; Tool
                                My homez.g file
                                ; homeZ.g
                                ; 用于归零Z轴
                                M913 Z50                    ; drop motor current to 50%
                                M400
                                ;G1 H2 Y100 F10000           ; lift Y away
                                G1 H1 Z110 F700           ; move quickly to Z axis endstop and stop there (first pass)
                                G1 H2 Z-5 F700            ; go back a few mm
                                G1 H2 Z-115 F700           ; move Z axis to the mid
                                M400
                                M400
                                  Phaedrux Moderator @NO1NOKAO
                                  @NO1NOKAO said in HOWTO Configure Z axis sensorless homing in homey.g file?:
                                  Your minimum and maximum for the Z axis seem backwards in this command.
                                  G1 H1 Z110 F700
                                  How fast can you reliably move the Z axis before it stalls on it's own?
                                  M913 Z50
                                  How low can you set the Z current before the Z axis just stalls on it's own?
                                  Try and find the minimum current and maximum speed you can move Z at, and then try and use the stall detection homing again.
                                  • NO1NOKAOundefined
                                    NO1NOKAO @Phaedrux
                                    @Phaedrux It worked😊 , I droped the current to 30% and increased the speed to 1000 and the feedback surprised me a lot. It's so kind of you to offer me so much valuable advice.
