    Height Map shifted downwards
    • Tryptamineundefined
      Tryptamine
      Hello, lovely members of this forum,
      I have a very strange behavior when creating a height map (G29 S0):
      The whole map is shifted downwards by around 0.6mm.
      Why is this the case?
      In my understanding, the point where z=0 is taken should be the point of the height map that is at 0. Why is none of the points at 0?
      My homing and config files are normal:
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v3.3.12 on Tue Aug 09 2022 15:55:52 GMT+0200 (Mitteleuropäische Sommerzeit)
      M402
      G91                      ; relative positioning
      G1 H2 Z3 F18000          ; lift Z relative to current position
      G1 H1 X-350 Y-310 F12000 ; move quickly to X or Y endstop and stop there (first pass)
      G1 H1 X-350              ; home X axis
      G1 H1 Y-310              ; home Y axis
      G1 X5 Y5 F18000          ; go back a few mm
      G1 H1 X-350 F1800        ; move slowly to X axis endstop once more (second pass)
      G1 H1 Y-310              ; then move slowly to Y axis endstop
      G90                      ; absolute positioning
      G1 X162 Y152  F18000        ; go to first bed probe point and home Z
      G30                      ; home Z by probing the bed
      ;G91                     ; relative positioning
      ;G1 Z3 F300              ; lift Z relative to current position
      ;G90                     ; absolute positioning
      ; Configuration file for Duet WiFi (firmware version 3.3)
      M575 P1 S1 B57600                                  ; enable support for PanelDue
      M550 P"HCEvo"                                      ; set printer name
      M669 K1                                            ; select CoreXY mode
      M569 P0 S0                                         ; physical drive 0 goes forwards
      M569 P1 S0                                         ; physical drive 1 goes forwards
      M569 P2 S1                                         ; physical drive 2 goes forwards
      M569 P3 S0                                         ; physical drive 3 goes forwards
      M584 X0 Y1 Z2:4 E3                                   ; set drive mapping
      M92 X160.00 Y160.00 Z800.00 E420.00                ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E1200.00               ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z1800.00 E8000.00          ; set maximum speeds (mm/min)
      M201 X5000.00 Y5000.00 Z20.00 E4000.00             ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z800 E1000 I30                    ; set motor currents (mA) and motor idle factor in per cent
      M208 X345 Y305 Z290 S0                             ; set axis maxima
      M574 X1 S1 P"xstop"                                ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                                ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
      M950 S0 C"exp.heater3"                             ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H3 F180 T18000               ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X28 Y9 Z0.5                                 ; set Z probe trigger value, offset and trigger height
      M557 X28:328 Y9:309 P2                           ; define mesh grid
      M308 S0 P"e1temp" Y"thermistor" T105526 B4138      ; configure sensor 0 as thermistor on pin e1temp (bedtemp BROKEN)
      M308 S1 P"e0temp" Y"thermistor" T103901 B4138      ; configure sensor 1 as thermistor on pin e0temp
      M307 H1 R10.976 K0.652:0.000 D2.65 E1.35 S0.30 B0 V24.0
      M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T120                                 ; set fan 1 value. Thermostatic control is turned on
      M572 D0 S0.38 ;0.64 fuer 0.4mm Nozzle
        droftarts administrators @Tryptamine
        @Tryptamine This usually happens because Z is not homed, or is homed with an incorrect offset, or if the Z is moved after homing and reset to Z0. I can see you are using a BLTouch to home Z in homeall.g. The Z offset is very small at 0.5mm, though. Do you do anything else before sending G29 S0? Do you have a sys/mesh.g file? Please also post what firmware version you're using.
          Please keep it to a single topic
          https://forum.duet3d.com/topic/30594/significant-z-offset-of-bed-mesh?_=1670008389610
