    Emergency stop without input
    • MortarArtundefined
      MortarArt
      Twice now, my Duet Wifi 1.02 printer has E-stopped, without any interaction. The console reports:
      Cancelled printing file ****.gcode, print time was Xh XXm
      Emergency Stop! Reset the controller to continue.
      The second time this occurred a dialog popped up in DWC stating that the firmware still reports that it's halted, asking whether I want to restart again. Restarting again resulted in a printer reporting idle.
      Firmware version is 2.02(RTOS) (2018-12-24b1)
      I have a PanelDue attached, and no separate E-stop wired up.
      Is this likely due to a fault in the panel?
      weed2allundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • weed2allundefined
        weed2all @MortarArt
        @MortarArt have you consider updating to at least latest v2 firmware wich is 2.05 if you don't want to update to v3 firmware!
        https://www.thingiverse.com/weed2all/designs
          dc42 administrators @MortarArt
          @MortarArt most likely the PanelDue cable is picking up interference from a nearby cable connected to a stepper motor. More recent firmware versions have improved protection against this type of interference.
          MortarArtundefined 1 Reply Last reply Reply Quote 0
            If you still have access to DWC. Upload these zip files, one at a time in the system tab. Don't extract them first. Reboot after each. Use M115 in the gcode console to verify the firmware has been applied.
            https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
            https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.3/Duet2and3Firmware-3.4.3.zip
            https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.4/Duet2and3Firmware-3.4.4.zip
            That will get your firmware and DWC up to date.
            You can see the change logs here:
            https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x
            For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
            https://configtool.reprapfirmware.org/Start
            Backup your existing config files in the sys folder in case you want to switch back to RRF2. It’s easy to switch back and forth, just upload the zip file for the version you want and then upload your config files.
            These documents will come in handy during the conversion.
            https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
              MortarArt @dc42
              @dc42 That's interesting that you're able to do a software fix for hardware interference. I'm curious how that works. But I think I'm happy enough with confirmation that this could be the panel.
              I'll update the firmware and see how I go.
                MortarArt @Phaedrux
                @Phaedrux Thank you for the detailed instructions!
                  Phaedrux Moderator @MortarArt
                  @MortarArt said in Emergency stop without input:
                  error correction
                  If you update your firmwares, don't forget to update the panel due firmware as well.
                  https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDue
