    Connection to wifi after update 3.4.5
    Firmware installation
    • bastundefined
      bast
      board>>duet 2 wifi
      after updating to 3.4.5, I can no longer connect to my board's wifi (i can control printer with duet panel)
      To talk with the board I use YAT
      m122
      === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.5 (2022-11-30 19:36:12) running on Duet WiFi 1.02 or later<LF>Board ID: 08DJM-9178L-L4MSN-6JTD8-3SS6N-K82YQ<LF>Used output buffers: 3 of 26 (11 max)<LF>=== RTOS ===<LF>Static ram: 23836<LF>Dynamic ram: 75420 of which 0 recycled<LF>Never used RAM 12824, free system stack 192 words<LF>Tasks: NETWORK(ready,8.3%,517) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,363) MAIN(running,91.7%,412) IDLE(ready,0.0%,30), total 100.0%<LF>Owned mutexes: USB(MAIN)<LF>=== Platform ===<LF>Last reset 00:05:08 ago, cause: power up<LF>Last software reset time unknown, reason: User, GCodes spinning, available RAM 12752, slot 0<LF>Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a<LF>Error status: 0x00<LF>Aux0 errors 0,0,0<LF>Step timer max interval 0<LF>MCU temperature: min 29.3, current 29.8, max 30.4<LF>Supply voltage: min 0.1, current 0.4, max 0.5, under voltage events: 0, over voltage events: 0, power good: no<LF>Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0<LF>Events: 0 queued, 0 completed<LF>Driver 0: ok, SG min n/a<LF>Driver 1: ok, SG min n/a<LF>Driver 2: ok, SG min n/a<LF>Driver 3: ok, SG min n/a<LF>Driver 4: ok, SG min n/a<LF>Driver 5: <LF>Driver 6: <LF>Driver 7: <LF>Driver 8: <LF>Driver 9: <LF>Driver 10: <LF>Driver 11: <LF>Date/time: 1970-01-01 00:00:00<LF>Cache data hit count 4294967295<LF>Slowest loop: 101.16ms; fastest: 0.15ms<LF>I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0<LF>=== Storage ===<LF>Free file entries: 10<LF>SD card 0 detected, interface speed: 20.0MBytes/sec<LF>SD card longest read time 1.1ms, write time 0.0ms, max retries 0<LF>=== Move ===<LF>DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000<LF>=== MainDDARing ===<LF>Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1<LF>=== AuxDDARing ===<LF>Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1<LF>=== Heat ===<LF>Bed heaters 0 -1 -1 -1, chamber heaters 2 -1 -1 -1, ordering errs 0<LF>=== GCodes ===<LF>Segments left: 0<LF>Movement lock held by null<LF>HTTP is idle in state(s) 0<LF>Telnet is idle in state(s) 0<LF>File is idle in state(s) 0<LF>USB is ready with "m122" in state(s) 0<LF>Aux is idle in state(s) 0<LF>Trigger is idle in state(s) 0<LF>Queue is idle in state(s) 0<LF>LCD is idle in state(s) 0<LF>Daemon is idle in state(s) 0<LF>Autopause is idle in state(s) 0<LF>Code queue is empty<LF>=== Network ===<LF>Slowest loop: 1.03ms; fastest: 0.00ms<LF>Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)<LF>HTTP sessions: 0 of 8<LF>= WiFi =<LF>Network state is starting2<LF>WiFi module is disabled<LF>Failed messages: pending 0, notready 1, noresp 0<LF>Socket states: 0 0 0 0 0 0 0 0<LF>ok<LF>
      m115
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.4.5 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2022-11-30 19:36:12<LF>ok<LF>
      m552
      WiFi module is being started<LF>ok<LF>
      wifi module isn't IDLE with M552
      I think the wifi of the board has a problem can you help me thank you
      bastundefined 1 Reply Last reply Reply Quote 0
      • bastundefined
        bast @bast
        M997 S0:1
        Error: M997: File 0:/firmware/DuetWiFiServer.bin not found<LF>ok<LF>
        DuetWiFIServer.bin is in my system file (263Ko)
          Phaedrux Moderator @bast
          @bast said in Connection to wifi after update 3.4.5:
          Make sure the wifi server bin file is present in the firmware folder.
          • bastundefined
            bast @Phaedrux
            @Phaedrux
            thanks 😉 it' solved with manualy update firware (copy past firmware on sd card )
              Perhaps to ensure that everything is now in the right place for the next update, you may wish to upload the 3.4.5 zip file once more to the system tab.
              https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet2and3Firmware-3.4.5.zip
