    Folder Accidently Deleted
    1.2k
    • mesacrashundefined
      mesacrash
      I went into my system folder on my SD card. Somehow the system folder got deleted. I formatted the SD card, so now I have nothing. It is the card that came with my new Duet 2 wifi. I am not sure which, and what to download and install. The firmware version names are confusing to me. Can I get what I need from you? Then I can use the tool to start configuration.
        droftarts administrators
        @mesacrash If you didn't have a configuration on the SD card, there's no real loss. For a guide on recreating the SD card, see https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#creating-the-file-structure
        This is the config.g file that is usually supplied on the SD card: config.g. Download it, rename it to 'config.g' and put it in the 'sys' folder on the SD card. All it does is start networking on the Duet, but should make initial connecting easier.
        Then follow the 'Getting connected' guide: https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet
        This explains how to connect via USB, and get the firmware version of your Duet. Use that to get the the matching firmware release from https://github.com/Duet3D/RepRapFirmware/releases and add the Duet Web Control (DWC) files from that to the SD card. Then you should be able to connect to DWC over your network.
        mesacrashundefined 1 Reply Last reply Reply Quote 0
          mesacrash @droftarts
          @droftarts I got connected but I get an error saying, "the drive is unmounted". Then when I did a refresh it came back with, "Your Duet rejected the HTTP request"
            Do you know what firmware version you have installed?
            If you have a USB terminal connection like YAT you can send M115 to check.
            You'll also need a WWW folder on the SD card that contains the web interface files. Those files will need to match the version of your firmware.
            Once you determine your firmware version you can download the files here. https://github.com/Duet3D/DuetWebControl/releases
            You want the DuetWebControl-SD.zip file and extract it into the WWW folder in the root of the SD card.
            If you've lost your entire configuration it may be a good idea to create a fresh config set using the online tool as well.
            https://configtool.reprapfirmware.org/Start
            mesacrashundefined 2 Replies Last reply Reply Quote 0
              mesacrash @Phaedrux
              @Phaedrux Thank you, I have done all that and still nothing. I have checked myself and still nothing.
                mesacrash @mesacrash
                This post is deleted!
                  mesacrash @Phaedrux
                  @Phaedrux would pictures help?
                    droftarts administrators @mesacrash
                    @mesacrash Possibly, yes. We really need to know what firmware you are running, and the layout of the files on the SD card. What do you see when you connect via USB?
                      @droftarts I am running 3.4.5 in a Duet 2 wifi. YAT talks to it through USB. This pic shows the card.Duet Files.jpg
                      I have the exact copy of this running a different machine as well.
                        Can you show the contents of the WWW folder?
                        Can you send M122 in YAT and copy and paste the results. Make sure you have your line endings set so we can see the full report.
                          mesacrash @Phaedrux
                          @Phaedrux I am new to YAT and am embarrassed to say, I do not know how to set the line endings. Let me work on that.
                            mesacrash @Phaedrux
                            @Phaedrux Does this work?
                            === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.5 (2022-11-30 19:36:12) running on Duet WiFi 1.02 or later<LF>Board ID: 0JD2M-9F8TA-GJ4TD-6J9F8-3S46Q-T7NQ7<LF>Used output buffers: 1 of 26 (2 max)<LF>=== RTOS ===<LF>Static ram: 23836<LF>Dynamic ram: 73384 of which 0 recycled<LF>Never used RAM 14860, free system stack 170 words<LF>Tasks: NETWORK(ready,27.6%,350) HEAT(notifyWait,0.0%,388) Move(notifyWait,0.0%,363) MAIN(running,72.4%,441) IDLE(ready,0.0%,30), total 100.0%<LF>Owned mutexes: WiFi(NETWORK) USB(MAIN)<LF>=== Platform ===<LF>Last reset 02:23:49 ago, cause: power up<LF>Last software reset at 2022-12-07 15:51, reason: User, GCodes spinning, available RAM 12904, slot 1<LF>Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a<LF>Error status: 0x00<LF>Step timer max interval 0<LF>MCU temperature: min 25.1, current 25.5, max 29.0<LF>Supply voltage: min 0.3, current 24.1, max 24.4, under voltage events: 1, over voltage events: 0, power[Warning: Maximal number of characters per line exceeded! Check the line break settings in Terminal > Settings > Text or increase the limit in Terminal > Settings > Advanced.]
                              @mesacrash The file structure in www looks correct. But the date of 9/30/22 on some of the files makes me think you're using an older version of DWC. Use this one from the 3.4.5 release: https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/DuetWebControl-SD.zip
                              See here for YAT line endings, under 'YAT settings': https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet#h-3-connect-to-duet
                              YATSet YAT to use <LF> as the end of line character. This will improve the readability of the messages coming from the Duet. Click "Text Settings" in the "Terminal Settings" and change "EOL sequence:" to <LF>. Click "OK" to close Text Settings. Click "OK" again to close Terminal Settings.
                                @droftarts Oh that, yes I do know how to do that.
                                M122<CR>
                                Static ram: 23836
                                Error status: 0x00
                                Supply voltage: min 0.3, current 24.1, max 24.4, under voltage events: 1, over voltage events: 0, power good: yes
                                Events: 0 queued, 0 completed
                                Driver 0: standstill, SG min n/a
                                Driver 1: standstill, SG min n/a
                                Driver 2: standstill, SG min n/a
                                Driver 3: standstill, SG min n/a
                                Driver 4: standstill, SG min n/a
                                Driver 5:
                                Driver 6:
                                Driver 7:
                                Driver 8:
                                Driver 9:
                                Driver 10:
                                Driver 11:
                                Slowest loop: 99.91ms; fastest: 0.13ms
                                === Storage ===
                                Free file entries: 10
                                SD card longest read time 9.5ms, write time 0.0ms, max retries 0
                                DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                                === MainDDARing ===
                                === AuxDDARing ===
                                Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                                Segments left: 0
                                Movement lock held by null
                                HTTP is idle in state(s) 0
                                Telnet is idle in state(s) 0
                                File is idle in state(s) 0
                                USB is ready with "M122" in state(s) 0
                                Aux is idle in state(s) 0
                                Trigger is idle in state(s) 0
                                Queue is idle in state(s) 0
                                LCD is idle in state(s) 0
                                Daemon is idle in state(s) 0
                                Code queue is empty
                                === Network ===
                                Slowest loop: 15.25ms; fastest: 0.00ms
                                Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                                HTTP sessions: 0 of 8
                                = WiFi =
                                Network state is active
                                WiFi firmware version 1.26
                                WiFi MAC address a4:e5:7c:03:b4:53
                                WiFi Vcc 3.42, reset reason Power up
                                WiFi flash size 2097152, free heap 27016
                                WiFi IP address 192.168.1.8
                                WiFi signal strength -35dBm, mode 802.11n, reconnections 0, sleep mode modem
                                Clock register 00002002
                                ok
                                Warning: VIN under-voltage event (9.5V)
                                  @mesacrash said in Folder Accidently Deleted:
                                  === Storage ===
                                  This is the bit we are interested in, and it says that the SD card interface is working correctly. If you send M20 P"0:/www/" what does it list?
                                  I can also see that you have it connected to the access point, and have an IP address, so you have managed that part. Have you made any changes to the sys/config.g file? Did you use the one I posted earlier?
                                    @droftarts said in Folder Accidently Deleted:
                                    M20 P"0:/www/"
                                    M20 P"0:/www/"
                                    Begin file list
                                    NONE
                                    End file list
                                    ok
                                    Yes it is in there, now.
                                      You mean the SD card is in the Duet? Make sure you have pushed it in far enough that it clicks in. Also, the card needs to be in when you turn on the Duet, or it will think there is no card mounted.
                                      Please can you send M39 and then M20 P"0:/sys/"
                                      mesacrashundefined 3 Replies Last reply Reply Quote 0
                                        @droftarts Is M20 telling us there is nothing in www?
                                          @droftarts no, I meant your config is in there now. I put it in and it still wasn't working so I changed back temporarily, to test. This is in a custom that I recently decided to put the duet in. I had it working but, a few days ago I took the card out and put it in my PC, something happened in Explorer and when I re-opened it my sys file folder was empty. Now, here we are today.
                                            @droftarts M39 says, "no sd card"
