    My Mac won't connect with my Duet 3d via WIFI
    • hlauprechtundefined
      hlauprecht
      Hello! So, I have my new Duet 3D and was able to connect to my Macbook Pro no problem. I was able to use it via WIFI the next day, also no problem. Couple days later my mac can't connect to the Duet 3D. I pinged the Duet's IP address and nothing. Tried accessing the control panel through the browser by entering the IP address and nothing. However, I was able to connect to the control panel using its IP address with my phone. So, I know that the Duet if connected to WIFI and active. Any idea what could be blocking the communication between my Mac and the Duet? I did have the VPN disconnected btw.
      hlauprechtundefined 1 Reply Last reply Reply Quote 0
        What is the IP address of the Duet?
        What is the IP address of the Mac?
          hlauprecht @hlauprecht
          @hlauprecht The Duet in on 192.163.1.73 and the mac is on 192.163.1.68
          hlauprechtundefined markzundefined 2 Replies Last reply Reply Quote 0
            Is the Mac wired, or wireless?
            If wireless, can you try turning wifi off, and on again? Then try pinging it.
              @hlauprecht Thank you for your response. The weird thing is that my iphone can connect to the Duet but I cannot connect from the mac. If I ping from the mac it says it can't connect.
              • markzundefined
                markz @hlauprecht
                @hlauprecht Did you mean 192.168? The 192.163 subnet isn't a private network address.
                  hlauprecht @markz
                  @markz Good morning, I am so sorry, you are right, I meant 192.168
