    Heightmap stats "dragged out/down"
    Duet Web Control
    • Exerqtorundefined
      Exerqtor
      Might be my monitor / resolution causing this issue, but if i look at my mesh heightmap the stats/info on the righthand pane are dragged out with an LARGE spacing unless i zoom the window/tab into 175%.
      Screenshots of what I'm talking about:
      100% / no magnification:
      175% magnification:
      Am I just being picky, or wouldn't it be better to have it spaced up like it is in 175% magnification by default? (I think it maybe was that way back in the day even?)
      This is running RRF / DWC 3.4.5 on a 34" monitor @ 3440x1440 resolution using Chrome version 108.0.5359.99 (Win10 x64).
      Sindariusundefined 1 Reply Last reply Reply Quote 0
        If you resize the window to a 16:9 aspect does it change back?
        Exerqtorundefined 1 Reply Last reply Reply Quote 0
        • Exerqtorundefined
          Exerqtor @Phaedrux
          @Phaedrux
          Yeah it does, so it looks like it's a scaling issue realted to having more than 16:9 aspect ratio😅
          • Sindariusundefined
            Sindarius @Exerqtor
            @Exerqtor this should be addressed in 3.5.
            • Exerqtorundefined
              Exerqtor @Sindarius
              @Sindarius
              Sweet, first time in a long time i look forrward to a RRF update 😅
              • Exerqtorundefined Exerqtor marked this topic as a question
              • Exerqtorundefined Exerqtor has marked this topic as solved
