    Incorrect determination of model height
    1.5k
    • Plohishundefined
      Plohish
      Today I started printing another model.
      The duet again incorrectly determines the height of the product and therefore the number of layers.
      Tell me what am I doing wrong?
      Model code link
      Please forgive my bad English, it's Google's fault :)
      • chrishammundefined
        chrishamm administrators @Plohish
        @Plohish The object height is displayed correctly on my machines. What firmware version are you using? Maybe you need to upgrade to the latest version.
        Duet software engineer
        Plohishundefined 2 Replies Last reply Reply Quote 0
        • Plohishundefined
          Plohish @chrishamm
          @chrishamm I use 3_2_2 version firmware
            @Plohish Upgrade to 3.4.5 then.
            Plohishundefined 3 Replies Last reply Reply Quote 0
            • Plohishundefined
              Plohish @chrishamm
              @chrishamm thanks i will try to do that
              • Plohishundefined
                Plohish @chrishamm
                @chrishamm how long does the update take? I uploaded the file and for about 15 minutes I see this picture
                  jay_s_uk @Plohish
                  @Plohish about 30 seconds or so.
                  Reboot and see what happens. What board are you using?
                  Plohishundefined 1 Reply Last reply Reply Quote 0
                  • Plohishundefined
                    Plohish @jay_s_uk
                    @jay_s_uk my Duet my duet turns on and off immediately
                      jay_s_uk @Plohish
                      @Plohish what duet do you have?
                      i'm assuming standalone rather than SBC?
                      what is the diag light like when power is supplied to the board?
                      • Plohishundefined
                        Plohish @jay_s_uk
                        @jay_s_uk Duet 2 WiFi
                        • Plohishundefined
                          Plohish @Plohish
                          Video
                          https://youtu.be/CSoKoNDBVsc
                            jay_s_uk @Plohish
                            @Plohish looks like a clone board so who knows whats going on.
                            you could try and recover it
                            https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#fallback-procedure-2
                            • Plohishundefined
                              Plohish @jay_s_uk
                              @jay_s_uk I have an "auto power off" board
                              Firmware Duet and Panelduo were successful.
                              However, now the VIN is not retained on the "auto power off" board.
                                jay_s_uk @Plohish
                                @Plohish the functionality of M80/M81 was changed in 3.4 https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x#:~:text=There is no longer a power,to start with VIN power off.
                                best check the change notes for anything else
                                • Plohishundefined
                                  Plohish @jay_s_uk
                                  @jay_s_uk thanks, tell me how should I change the control string for PS_ON ?
                                    jay_s_uk @Plohish
                                    @Plohish https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m80-atx-power-on
                                    • Plohishundefined
                                      Plohish @jay_s_uk
                                      @jay_s_uk thanks, you helped me a lot!
                                      • Plohishundefined
                                        Plohish @chrishamm
                                        @chrishamm Good afternoon! I updated the firmware to 3.4.5
                                        The code that I showed above is also not processed correctly! Model height 5mm instead of 150mm
                                        I don't understand how it worked correctly on your machine?
                                        • Plohishundefined
                                          Plohish @chrishamm
                                          @chrishamm I have a model again where Duet can't determine the model's height and layer thickness
                                          I use 3.4.5 firmware
                                          Link model code
                                          • Plohishundefined
                                            Plohish
                                            very strange!
                                            in the tab "G-code" I see both the height of the model and the thickness of the layer!
                                            why can't the "status" tab display this?
