Incorrect determination of model height
@Plohish about 30 seconds or so.
Reboot and see what happens. What board are you using? -
@jay_s_uk my Duet my duet turns on and off immediately
@Plohish what duet do you have?
i'm assuming standalone rather than SBC?
what is the diag light like when power is supplied to the board? -
@jay_s_uk Duet 2 WiFi
@Plohish looks like a clone board so who knows whats going on.
you could try and recover it
https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#fallback-procedure-2 -
@jay_s_uk I have an "auto power off" board
Firmware Duet and Panelduo were successful.
However, now the VIN is not retained on the "auto power off" board. -
@Plohish the functionality of M80/M81 was changed in 3.4 https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x#:~:text=There is no longer a power,to start with VIN power off.
best check the change notes for anything else -
@jay_s_uk thanks, tell me how should I change the control string for PS_ON ?
@jay_s_uk thanks, you helped me a lot!
@chrishamm Good afternoon! I updated the firmware to 3.4.5
The code that I showed above is also not processed correctly! Model height 5mm instead of 150mm
I don't understand how it worked correctly on your machine? -
@chrishamm I have a model again where Duet can't determine the model's height and layer thickness
I use 3.4.5 firmware
Link model code
very strange!
in the tab "G-code" I see both the height of the model and the thickness of the layer!
why can't the "status" tab display this? -
help me somebody...
please. -
@Plohish Its the holiday season, Diet3D peeps deserve some time with family and friends.
Also, 3.5.0b1 just was released which has a rewritten DWC, so maybe try that?
@oliof I'm sorry, I certainly understand that people are resting ...
Now I'll make a video, the system works with errors... Sometimes it does not the height of the model and the thickness of the layer at all, sometimes the system takes these values from the previous model...
in version 3.2.2 it worked much more correctly! -
First I do a cube printing simulation,
file date - 2022.12.19
file time -17:04:19
Then I do a simulation of another model
file date - 2022.12.22
file time -15:07:42
However, I see old data when simulating, note model height, file date and time. -
When you try to upload a file for printing, the system starts to heat the table but does not see the height of the part and the height of the layer.
But if you press "emergency stop", the system starts to display the height parameters.
https://youtu.be/CpHbIIgSdyI -
Gentlemen, I appeal to you again, help me understand why Duet 2 WiFi does not determine the height of the model and the number of layers for printing?
here is the new file
