    Paste estruder configuration
    Config Tool
    561
    • GiusepRapundefined
      GiusepRap
      Hi guys
      I’m trying to configure my Duet Wi-Fi mini for a ceramic “cold” extruder.
      How can I do ? I don’t need of temperature sensor and heater.
      Regards
      Giuseppe
        You can define a tool without a heater and then enable cold extrusion with M302.
        https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m302-allow-cold-extrudes
        GiusepRapundefined 1 Reply Last reply Reply Quote 0
        • Phaedruxundefined Phaedrux referenced this topic
          GiusepRap @Phaedrux
          @Phaedrux thanks
            dc42 administrators @GiusepRap
            @GiusepRap if there is no tool heater then you won't need to use M302 because the firmware should allow cold extrusion automatically.
            GiusepRapundefined 1 Reply Last reply Reply Quote 1
              GiusepRap @dc42
              I’ve installed dual z axis, x and y end extruder
              but when I launch de web app the extruder command is “locked” and it cannot extrude
              This is my configuration
              Drives
              M569 P0.1 S1 ; physical drive 0.1 goes forwards
              M569 P0.2 S1 ; physical drive 0.2 goes forwards
              M569 P0.3 S0
              M584 X0.0 Y0.3 Z0.2:0.4 E0.1
              Regards
              Giuseppe
                Do you have the tool selected?
                Post your full config.g and the results of sending M122 in the gcode console tab in DWC please.
                GiusepRapundefined 2 Replies Last reply Reply Quote 0
                  GiusepRap @Phaedrux
                  This post is deleted!
                    GiusepRap @Phaedrux
                      Not sure why you deleted your posts, but you should update your firmware.
                      https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#duet-3-mini-5-wifiethernet
                        GiusepRap @Phaedrux
                        @Phaedrux thanks 😅 I deleted for rewriting better but I couldn’t. Thanks, now I try ti update the firmware and After I check it again. Regards Giuseppe
