I can't get my BLTouch to work
I have a Duet 2 wifi board I installed in my Creality CR-5. I hated that printer until I put the Duet in it. I configured it myself and it works like a champ. I put a Duet in my custom cartesian printer and I can't get my BLTouch to work. My custom cartesian worked before, but not as well as my CR-5. Below are examples of what is in my config. I have tried all 3 and M401/M402 do nothing.
This is what is in my CR-5, that I love:
G31 P500 X10 Y10 Z3.15 ; set Z probe trigger value, offset and trigger height
M557 X15:275 Y15:195 S20 ; define mesh grid
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speedsThis is what came on the SD card in my new Duet board:
M558 P1 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
G31 P500 X-50 Y-15 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:275 Y15:215 S20 ; define mesh gridThis is what was sent to me by???
G31 P500 X40 Y15 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:275 Y15:215 S20 ; define mesh gridCan anyone be of help?
Please post your config.g, homeall.g, homez.g, deployprobe.g, retractprobe.g files and the results of M122 and M98 P"config.g"
; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.15 on Fri Dec 16 2022 18:59:05 GMT-0600 (Central Standard Time); General preferences
M550 P"Duet CR-ASH" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes forwards
M569 P1 S0 ; physical drive 1 goes forwards
M569 P2 S0 ; physical drive 2 goes forwards
M569 P3 S0 ; physical drive 3 goes forwards
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X300 Y240 Z220 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y1 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch; Heaters
M143 H1 S300 ; set temperature limit for heater 1 to 300C; Fans
M106 P0 S0.3 H-1 ; set fan 0 value. Thermostatic control is turned off
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
@Phaedrux ; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.3.13 on Fri Sep 30 2022 17:14:47 GMT-0500 (Central Daylight Time)
G91 ; relative positioning
G1 H1 X-305 Y-230 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-305 Y-230 F360 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 X5 Y5 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioning -
@Phaedrux ; homez.g
; called to home the Z axis
; generated by RepRapFirmware Configuration Tool v3.3.13 on Fri Sep 30 2022 17:14:48 GMT-0500 (Central Daylight Time)
G1 X5 Y5 F6000 ; go to first probe point
@Phaedrux ; deployprobe.g
; called to deploy a physical Z probe
M280 P0 S10 ; deploy BLTouch -
@Phaedrux ; retractprobe.g
; called to retract a physical Z probe
M280 P0 S90 ; retract BLTouch -
@Phaedrux 12/30/2022, 6:30:55 PM M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.5 (2022-11-30 19:36:12) running on Duet WiFi 1.02 or later
Board ID: 0JD2M-9F8TA-GJ4TD-6J1FD-3S86K-9RPY6
Used output buffers: 1 of 26 (12 max)
Static ram: 23836
Dynamic ram: 75232 of which 12 recycled
Never used RAM 12928, free system stack 152 words
Tasks: NETWORK(ready,14.5%,242) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,294) MAIN(running,85.5%,446) IDLE(ready,0.0%,30), total 100.0%
Owned mutexes: WiFi(NETWORK)
Last reset 00:57:32 ago, cause: software
Last software reset at 2022-12-30 17:33, reason: User, GCodes spinning, available RAM 12852, slot 0
Error status: 0x00
Step timer max interval 0
MCU temperature: min 23.9, current 24.5, max 25.1
Supply voltage: min 23.9, current 24.1, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
Events: 3 queued, 3 completed
Driver 0: standstill, SG min 0
Driver 1: standstill, SG min n/a
Driver 2: standstill, SG min n/a
Driver 3: standstill, SG min n/a
Driver 4: standstill, SG min n/a
Driver 5:
Driver 6:
Driver 7:
Driver 8:
Driver 9:
Driver 10:
Driver 11:
Date/time: 2022-12-30 18:30:53
Slowest loop: 6.40ms; fastest: 0.15ms
=== Storage ===
Free file entries: 10
SD card longest read time 0.6ms, write time 0.0ms, max retries 0
DMs created 83, segments created 3, maxWait 256088ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
Scheduled moves 6, completed 6, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty
=== Network ===
Slowest loop: 15.54ms; fastest: 0.00ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
HTTP sessions: 1 of 8
= WiFi =
Network state is active
WiFi firmware version 1.26
WiFi MAC address e8:68:e7:7f:6d:ba
WiFi Vcc 3.45, reset reason Power up
WiFi flash size 2097152, free heap 26936
WiFi IP address 192.168.1.9
WiFi signal strength -33dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
Socket states: 0 0 0 0 0 0 0 0 -
@Phaedrux 12/30/2022, 6:32:17 PM M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Warning: Heater 0 predicted maximum temperature at full power is 321°C -
This post is deleted! -
@Phaedrux I have posted all the files you requested. I'm sorry it took so long.
Is this a genuine BLTouch or a Creality version? The wiring is a bit different between them. Compare here: https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_connecting#bltouch
Regardless, your config looks ok, so I suspect either a wiring issue, or the probe itself isn't working.
@Phaedrux I had a bad cable. All is well with the BLTouch. Thank you
