    filament config for pellet extruder
    • ardisfundefined
      ardisf
      is the filament config for the pellet extruder different? in what part? thanks
        Can you be more detailed in what you're asking?
        ardisfundefined 1 Reply Last reply Reply Quote 0
        • ardisfundefined
          ardisf @Phaedrux
          @Phaedrux in duet web control, we must add filaments config right? which contains config, load, and unload.
          then, if I use a pellet extruder instead of filament, will the contents of the config be different from 3d printers in general
            The filament control is entirely optional. It allows you to set up some macros to help automate a load/unload process or to have specific settings for different materials/processes. That can be whatever you need it to be, but it is optional.
