    Content of bed.g?
    IR Height Sensor
    3.0k
    • peirofundefined
      peirof
      i have installed Mini Ir Height Sensor… think all works, but calibration at the half, send a error message, and stops.
      This message:
      [[language]]
         "Error: Z probe already triggered before probing move startedMacro file IN Up.g not found."
      Maybe the problem, is the content of bed.g, i have the same, when i have instaled BlTouch….
      Someone can post his bed.g file for compare?
      In this moment, i am using this:
      [[language]]
      ; bed.g
      ; called to perform automatic delta calibration via G32
      ; generated by RepRapFirmware Configuration Tool on Mon May 22 2017 22:56:20 GMT-0400 (Eastern Daylight Time)
      G28
      ; Clear any bed transform
      M561
      ; Probe the bed at 6 peripheral and 0 halfway points, and perform 3-factor auto compensation
      ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
      G28 ; home all
      G91 ; relative mode
      G1 Z15 F200 ; move Z 4mm for clearance
      G90 ;absolute mode
      M98 BLT PIN Down.g
      ; M401 _ In lieu of macro - call GCode for deploy probe
      G29 ; run auto bed mesh levl
      M98 BLT PIN Up.g
      ;M402 _In lieu of macro - call GCode to retract probe
      G1 X10 Y10 F5000
      Thanks
      • fulgundefined
        fulg
        Don't use spaces in your macro filenames… I believe this is the problem.
        Cheers,
        Ben.
        VORON V2 CoreXY + Duet3 Mini5+ Ethernet v1.0 with Mini2+ expansion, VORON V0 CoreXY + Duet2 Maestro
        • fulgundefined
          fulg
          Also, these macros are usually called deploy.g and retract.g, and are already automatically called by M401 and M402. Since Firmware 1.19, you no longer need to call M401/M402 explicitly for G29 or G32 to work.
          • fulgundefined
            fulg
            Lastly, here is my entire bed.g:
            [c]
            M561 ; clear any existing bed transform
            G1 F500
            ; bed points are in probe space…
            G30 P0 X20 Y70 Z-99999 ; define 4 points in a clockwise direction around the bed, starting near (0,0)
            G30 P1 X20 Y280 Z-99999
            G30 P2 X280 Y280 Z-99999
            G30 P3 X280 Y70 Z-99999
            G30 P4 X150 Y150 Z-99999 S0 ; finally probe bed centre, and calculate compensation
            ;G1 X0 Y0 F5000 ; move the head to the corner (optional)
            [/c]
            (next time I should think more before pressing Submit, sorry for the multiple sequential answers!)
            • peirofundefined
              peirof
              ok,
              later try… but my probe don't need to be deployed, these lines are in bed.g, when i have instaled a BlTouch. In this moment i have a Mini IR Sensor.
              Thanks
                Looks like 2 different errors:
                1. Probe triggered at start of move. Perhaps the G31 P parameter is wrong, or the dive height is too low.
                2. Trying to execute a macro file that it can't find.
                • Dougal1957undefined
                  Dougal1957
                  and I don't see any Probe points defined.
                  • peirofundefined
                    peirof
                    @dc42:
                    1. Probe triggered at start of move. Perhaps the, G31 P parameter is wrong, or the dive height is too low.
                    Now works….
                    I have raised the dive height...
