    Accelerometer causes out of memory issue
    • mrwizzardundefined
      mrwizzard
      Edit: i thought this happened after upgrading to RRF 3.4.5, please move to right forum.
      When using an accelerometer, detected in the input shaping plugin, homing the machine causes it to reset.
      Using this, which is correct for my setup i believe. removing this line from the config fixes the issue.
      M955 P0 C"spi.cs3+spi.cs4" I10 ;Accelerometer
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.5 (2022-11-30 19:36:12) running on Duet WiFi 1.02 or later + DueX5
      Board ID: 08DGM-9T6BU-FG3SN-6J9FJ-3SN6L-9SWVG
      Used output buffers: 1 of 26 (12 max)
      Static ram: 23836
      Dynamic ram: 85312 of which 0 recycled
      Never used RAM 76, free system stack 184 words
      Tasks: NETWORK(ready,10.8%,237) ACCEL(notifyWait,0.0%,348) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,363) DUEX(notifyWait,0.0%,24) MAIN(running,86.1%,444) IDLE(ready,3.1%,30), total 100.0%
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:00:24 ago, cause: software
      Last software reset at 2022-12-29 20:04, reason: OutOfMemory, GCodes spinning, available RAM 4, slot 0
      Software reset code 0x41c3 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x20003e38 Task Move Freestk 324 ok
      Stack: 2001aa5c 0041009d 00000002 00410273 00000008 00000014 20004038 0042b43f 2001aa78 00425223 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 6c000000 20003eec 2001d540 2000c9e4 20003f18 00000000 00016e35 00425659 3fb504f3
      Error status: 0x00
      Step timer max interval 0
      MCU temperature: min 25.0, current 25.5, max 29.3
      Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/3, heap memory allocated/used/recyclable 2048/46/0, gc cycles 0
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min n/a
      Driver 1: standstill, SG min n/a
      Driver 2: standstill, SG min n/a
      Driver 3: standstill, SG min n/a
      Driver 4: standstill, SG min n/a
      Driver 5: standstill, SG min n/a
      Driver 6: standstill, SG min n/a
      Driver 7: standstill, SG min n/a
      Driver 8: standstill, SG min n/a
      Driver 9: standstill, SG min n/a
      Driver 10:
      Driver 11:
      Date/time: 2022-12-29 20:05:23
      Cache data hit count 901695954
      Slowest loop: 6.54ms; fastest: 0.19ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 0.7ms, write time 0.0ms, max retries 0
      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      === AuxDDARing ===
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty
      === DueX ===
      Read count 1, 2.48 reads/min
      === Network ===
      Slowest loop: 128.53ms; fastest: 0.00ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 1 of 8
      = WiFi =
      Network state is active
      WiFi firmware version 1.27
      WiFi MAC address 84:f3:eb:83:2b:76
      WiFi Vcc 3.37, reset reason Power up
      WiFi flash size 4194304, free heap 24728
      WiFi IP address 192.168.20.49
      WiFi signal strength -52dBm, mode 802.11n, reconnections 0, sleep mode modem
      Clock register 00002002
        mrwizzard
        Also, there's no issue collecting the accelerometer data with M956, it creates a CSV with data.
        However this also happens in reverse. if i remove the accelerometer setup, home the machine then try to run M955 it will also crash with out of memory. so it's either connect the accelerometer or home the axis, can't have both. lol...
        edit: i've disable the display and freed up more memory and it works, for now.
        • T3P3Tonyundefined T3P3Tony moved this topic from Firmware installation
          dc42 administrators @mrwizzard
          @mrwizzard thanks for your feedback. Unfortunately, there is only 128kb RAM on Duet 2 and this is easily used up. When a Duet 2 WiFi is booted with a minimal config.g file, there are 15840 bytes of Never Used RAM according to M122. This is easily used up by such things as creating tools, creating variables, creating heaters and fans, configuring a 12864 display and creating menu items, and many other things. The 12864 display in particular uses quite a lot of RAM.
          I've been through the linker map to identify where we might save some RAM space several times already. I've just done that again and managed to increase the Never Used RAM on the same system to 16056 bytes. So 3.5beta2 may have a small amount of extra RAM available - if it doesn't get used by something else first.
