    CNC Pendant, again...
    Third-party add-ons
    • Nightowlundefined
      Nightowl
      I'm using a CNC pendant that I'm not particularly happy with, so I'm thinking about going down the route explained by Duet here, but has anyone had success with this, please?
      I'm not using a PanelDue, so I don't need the passthrough (if I understand that correctly) and I'll probably retain the multi-core wire, rather than replace it with 3/4 core, unless there is a distinct disadvantage!)
      Firstly, is the pendant fairly easy to source from the UK?
      Secondly, do the axes move per step when turning the rotary knob, in relation to the setting of the selector switch, and can the step size be programmed?
      Thirdly, what function does the E-Stop button serve, e.g. does/can it turn the controller board (Duet3 MB6HC in this case) off or does it just isolate power to the pendant?
      Thank you
      Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
      I'm still on my learning curve, so take everything I say with caution!
      RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
        dc42 administrators @Nightowl
        I don't have a CNC machine so I can't say how well it works in practice; but in answer to your questions:
        @Nightowl said in CNC Pendant, again...:
        The multicore cable is quite thick, that's why I used 4-core cable instead.
        https://www.amazon.co.uk/RATTMMOTOR-Electronic-Trailer-Emergency-Generator/dp/B08KZQP9XP
        The step size is determined by the setting of the x1/x10/x100 switch.
        It sends the Emergency Stop command to the Duet.
        Nightowlundefined 2 Replies Last reply Reply Quote 1
        • Nightowlundefined
          Nightowl @dc42
          Awesome, thank you @dc42
          • Nightowlundefined
            Nightowl @dc42
            Probably inappropriate to ask here, but how straightforward would it be to 'translate' the code for the Arduino version into the RPi version?
            If I'm going down this rabbit hole, I might as well start with the RPi, so I don't need to relearn everything, or worse - confuse one language with another!
              @Nightowl I am out of the office today, but as there is an Arduino port for the RP2040 then it's likely that the original Arduino program will work on the RP2040 if you adjust the pin numbers if needed.
