Hotend Cooling fan behaving erratically Toolboard 1LC
Hi all,
I'm setting up a Duet3 6HC right now. I have a Toolboard on a Hemera. The Hotend cooling fan is plugged into 121.out2. For some reason, the RPM of this fan does not stay constant, even though it should be at 100% when the hotend is above 55C. M107 from Prusaslicer will reduce the rpm of the fan. Running heater tuning will also reduce the rpm of the fan. I do not know how much the rpm is being reduced, but there is a very audible difference.
Relevant config.g
;Tool 0 (supervolcano hemera) M308 S1 P"121.temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin 121.temp0 M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency M106 P0 C"CPAP Blower" S0 L0.15 X1.0 H-1 ; set fan 2 value. Thermostatic control is turned off M950 F1 C"121.out2" Q500 ; create fan 1 on pin 121.out2 and set its frequency M106 P1 C"Hotend Fan" S1.0 H1 T55 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 S"main" D0 H1 F0:1 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C
@Surgikill is there a reason why you didn't use 121.out1 for your blower? Also, is there a reason you mapped both fan 0 & fan 1 to tool 1? If not, try changing the f parameter in m563 to just 0 as that is your part cooling fan.
@TRATOON That fixed it, thanks.
I used out2 because that's what I used I guess. Documentation said they were both good for fans, and the fan that I have is a 2 wire fan, so I didn't want to take up the more versatile output with a shitty fan. I might change it over to a 4 wire noctua. Need to see.
@Surgikill have you had any issues with your print cooling fan? Mine seems to always be running at 100% and doesn't responds to off/slow down commands.
@TRATOON I'm running a cpap blower, so I'm not using a part cooling fan on the toolboard. Port your config and I can take a look at it and see if I think there is anything odd about it.
It may also be your slicer settings. Not sure what slicer you are using, but maybe you have 'cooling fan always on' enabled?
undefined dc42 marked this topic as a question
undefined dc42 has marked this topic as solved
