Solved Magnetic Filament Sensor - Error codes
Hey,
I'm interested to learn what the different error codes mean that are sent to filament-error.g (and which ones exist in the first place), but I haven't found any documentation on them.
Can anyone help?
@Diamondback the error codes reported by the flashing LEDs are explained here:
https://docs.duet3d.com/en/User_manual/Connecting_hardware/Sensors_filament#troubleshooting@dc42 will need to confirm if these same error types are reported by the event system.
@Diamondback I have provisionally updated thr documentation here:
@T3P3Tony Awesome, thanks, from what i can see, the event itself only receives an int rather than a string about the error, can you add those as well?
(triggering the switch, ie "noFilament" appears to be 3 for example) -
@Diamondback thanks for checking, yes i will do
@T3P3Tony Thank you very much!
