    Input shaping without accelerometer
    1.5k
    • Adamfilipundefined
      Adamfilip
      Is it possible to calibrate input shaping without an accelerometer
      Can you just print a test tower with different frequency settings and compare results.
      since tests are needed to confirm results what is the main benefit of using accelerometer sensor?
      chrishammundefined CCS86undefined 2 Replies Last reply Reply Quote 0
      • chrishammundefined
        chrishamm administrators @Adamfilip
        @Adamfilip I think it is possible to approximate the ringing frequency by printing a sample, see https://www.klipper3d.org/Resonance_Compensation.html#ringing-frequency
        The main benefit of accelerometer-based tuning is that it is easier. Collected accelerometer data can be used to retrieve the ringing frequencies as well using FFT.
        Duet software engineer
        • CCS86undefined
          CCS86 @Adamfilip
          @Adamfilip said in Input shaping without accelerometer:
          Absolutely.
          I use custom "after layer change" g-code, in Superslicer, to sweep a range of frequencies:
          {if layer_num < 25}M593 P"none"
          {else}M593 P"MZV" F{15+(layer_num-25)*1.5}
          {endif}
          This will use no IS below layer 25. Then after that will use type:MZV (choose your type), starting with 15 Hz. By changing that 1.5 multiplier (depending on your print height) you can end at a specific frequency.
