    Filament sensor debouncing?
    353
    • zBeebleundefined
      zBeeble
      So... I looked at my previous filament sensor post --- and this deserves a new post.
      I bought some cheap filament sensors on Amazon. AFICT, they produce a positive spuriously but briefly. Now ... I could fix this with some sort of capacitor circuit --- but that is just not my wheelhouse.
      Now... my filament sensor is about 15 to 20 cm from the extruder --- so I'm fairly confident that a 1 second debounce could be added to software and/or to the M command that sets it up --- and that this would solve my problem.
      Equally, yes, I could not buy sensors on Amazon, but since I have, I'm hoping that this little feature request my save my (and other) butts in hindsight.
      OwenDundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • OwenDundefined
        OwenD @zBeeble
        @zBeeble
        You can check for bouncing in filament-error.g
        Note: On some firmware versions the name could be filament_error.g
        Something like this is sufficient if it is a simple switch.
        ; check if switch is bouncing
        G4 P10 ; delay 10ms to debounce
        if sensors.filamentMonitors[0].status="ok"
        	echo "switch bounce detected - error cancelled"
        	M99 ; break out if sensor value is zero again (bouncing)
        ;error persists so we pause print
        echo "Filament error - pause print"
        M25
        zBeebleundefined 3 Replies Last reply Reply Quote 0
        • zBeebleundefined
          zBeeble @OwenD
          @OwenD OK. Awesome. I don't even know where to look for this functionality in the docs, but I'm ecstatic that it's there. My mind is immediately thinking about a retry loop for certain types of actions...
          But back to the project --- my firmware is 3.4.1. Nearly current. filament-error.g?
          OwenDundefined 1 Reply Last reply Reply Quote 0
          • zBeebleundefined
            zBeeble @OwenD
            @OwenD Are we using python-esque indentation is scope here?
            • OwenDundefined
              OwenD @zBeeble
              @zBeeble
              Yes should be filament-error.g
              See M591 and Events for more info
              • OwenDundefined
                OwenD @zBeeble
                @zBeeble said in Filament sensor debouncing?:
                Yes.
                See here for more info on conditional code and meta commands
                  dc42 administrators @zBeeble
                  @zBeeble what problem is the bouncing causing? Bouncing should occur only when the state changes.
                  zBeebleundefined 1 Reply Last reply Reply Quote 0
                  • zBeebleundefined
                    zBeeble @dc42
                    @dc42 bouncing may not entirely be the right term. Maybe noise? I think the code will be correct, tho.
                    Basically, the filament enstop is "detected" ... but the filament went out --- and the LED is on. I can only assume that the sensor was only "off" for a very short time... as "off" is the runout condition.
                    I can feel a little microswitch in the sensor (it "clicks" when I push through a new filament). Given my recent experience with mouse switches, I can only assume the same thing --- that noise due to the switch being "on" (or contacting) but moving a bit --- noise is causing a momentary sensing of "off"
                    • zBeebleundefined
                      zBeeble @OwenD
                      @OwenD Just got verification that this works (at least to sense the filament not running out).
                      ... I increased it to 100ms to be pessimistic, but that would be correct... the printer is still (for a little while) in filament. It should run out for real (testing the other branch) before this print is through.
                      zBeebleundefined 1 Reply Last reply Reply Quote -1
                      • zBeebleundefined
                        zBeeble @zBeeble
                        @zBeeble So... after some time, I finally did run out of filament, and that, then, verified both branches ... "This works" ...
