    Duet 3 Mini 5+ Wifi Antenna Range?
    Using Duet Controllers
    • bpeters2
      bpeters2 last edited by bpeters2
      I just received a Duet 3 Mini 5+ Wifi and have found the range of the antenna extremely weak. My board only seems to connect once I'm literally sitting next to my router. I have a Duet 2 which runs great from my basement and connects to the router, so it is not an issue of the router. Is the antenna range of the Duet 3 Mini 5+ much less than the Duet 2? Am I missing something? Thanks in advance.
      • T3P3Tony
        T3P3Tony administrators @bpeters2 last edited by
        @bpeters2 the external antenna version of the Duet 2 Wifi and the Mini 5+ use the same antenna and in more recent versions of the Duet 2 the same wifi module.
        The external antenna does need to be properly seated in the small connector, please check that.
        www.duet3d.com
        bpeters2 1 Reply Last reply Reply Quote 0
        • bpeters2
          bpeters2 @T3P3Tony last edited by
          Thanks!
          Here is what I have. What do I need to check?
          @T3P3Tony said in Duet 3 Mini 5+ Wifi Antenna Range?:
            The antena must be connected to the golden circle part.
            • bpeters2
              bpeters2 @Phaedrux last edited by
              @Phaedrux Got it...thanks!
                If it wasn't connected before that would definitely explain the reduced range.
