duet 2 the wifi only works when plugged into usb
@jcwild said in duet 2 the wifi only works when plugged into usb:
@dc42 ok now where can i find the iap4e file? why are all these files so badly spread out and not just pre compiled into an sd card image?
Typically updating is done with the pre-made zip file via DWC. But that zip file also contains all the files needed for that release including the iap files.
@dc42 just updated to exactly what you linked and same deal. timing out
What error message do you get?
Can you send these commands one at a time and report the response you get?
M552 S-1
M552 S0
M552 S1
M997 S1
M588 S"*" ; this will clear all saved SSIDs and passwords
M587 S"Network-ssid" P"Password123" ; re-add your ssid and password -
@Phaedrux dont know what m552 s-1 does but ive dont plenty of toggling on and off with s0 and s1 and m587 ive done and redone after updating it with m997 s1
