    CAN Bus cable
    • J.Helpsundefined
      J.Helps
      Hi there!
      I am building a large 3D printer for my master's thesis and am having difficulty finding an unshielded twisted pair cable with a 120 ohm characteristic impedance for long cables. Is there a problem with using shielded twisted pair cables, which are more readily available? The Duet documentation recommends using unshielded cables for long distances, but I am unsure of the reason.
      Additionally, I am using 10 motors with 10 expansion boards (one board per motor) and was wondering if I can connect all of these boards in series using a CAN bus cable with four wires (two for the RJ11 connector and two for power supply). This would simplify my cable management, even if I use a separate cable for power supply and the CAN bus, but still connect them in series.
      Best regards,
      John Helps
        dc42 administrators @J.Helps
        @J-Helps yes you can use shielded twisted pair and shielded RJ11 or RJ12 connectors.
        If the 10 boards are EXP1HCLs then I don't advise daisy chaining the power to them all. Instead I suggest you daisy chain at most 3 or 4 and run each chain back to the PSU. If the boards are EXP1XDs then the power requirement is very low and daisy chaining power to them all should be OK.
        J.Helpsundefined 1 Reply Last reply Reply Quote 0
        • J.Helpsundefined
          J.Helps @dc42
          @dc42 Thank you very much!
          I have another question: How does the M597 command work to avoid collisions with two independent gantries with the new multiple motion systems feature of reprap firmware? I mean, if I set the "safe" distance of the gantries to 20mm, what happens when they reach that distance? Does one of them stop or slow down?
            @J-Helps if a potential collision is detected then the print is aborted.
