    need help with config.g for cr touch and swiss drive
    253
    • Flynbrdundefined
      Flynbrd
      System - Ender 3 v1 with duet2 wifi, swiss direct drive extruder, CR touch,
      I changed the setting in config.g for swiss direct drive and CR touch. Does this look correct?
      Original
      ;Z-Probe
      M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
      M307 H4 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
      M558 P9 H2.5 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
      G31 P25 X-48 Y-10 Z1.240 ; Set Z probe trigger value, offset and trigger height
      M557 X15:185 Y50:220 S35 ; Define mesh grid
      Modified
      M950 S0 C "io7.out"
      M558 P9 C "Io7.in" H5 F120 T6000
      G31 P1000 X-48 Y-10 Z2.5 ; Set Z probe trigger value, offset and trigger height
      Swiss direct drive changes
      original
      M92 X80.00 Y80.00 Z400 E90 ; Set steps per mm
      to
      M92 X80.00 Y80.00 Z400 E135
      original config.g file anything out of place?
      ; generated by RepRapFirmware Configuration Tool on Thu Sep 06 2018 21:21:12 GMT-0700 (Pacific Daylight Time)
      M550 Pe3 ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S0 ; Drive 0 goes backwards
      M92 X80.00 Y80.00 Z400 E135 ; Set steps per mm
      M566 X1000 Y1000 Z100 E30000 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000 Y6000 Z500 E1500 ; Set maximum speeds (mm/min)
      M201 X300 Y300 Z100 E5000 ; Set accelerations (mm/s^2) was 500 you changed it to 300 for stall guard
      M906 X500 Y500 Z500 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S300 ; Set idle timeout
      M208 X235 Y235 Z250 S0 ; Set axis maxima
      M574 X1 Y1 S1 ; Set active high endstops
      ;M305 P1 X150 T"K" ; Set THERMOCOUPLE parameters for heater 1 X150 is the right channel (terminal block) on the daughterboard. X151 is the left channel.
      M143 H1 S345 ; Set temperature limit for heater 1 to 345C
      M106 P0 S0 I0 B0.5 F250 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 B0.5 F500 L255 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Minimum Speed is 1/3 aka 87 Thermostatic control is turned on triggered at nozzle temp 45;
      M106 P2 S0 I0 B0.5 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 ; Define tool 0
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      ; Custom settings
      M591 D0 P5 C3 R10:300 E3.0 S1 ; Duet3D laser sensor for extruder drive 0 is connected to endstop input 3 (E0), tolerance 10 to 120%, 3mm comparison length
      0
      1 out of 1
        Please send M122 and M98 P"config.g" in the gcode console and copy and paste the results here. Would like to check your firmware version because your config is using old syntax.
        Flynbrdundefined 1 Reply Last reply Reply Quote 0
        • Flynbrdundefined
          Flynbrd @Phaedrux
          @Phaedrux Thank you for the quick reply, I keep trying to post but it's getting flagged as spam. going to try to break it up.
          = RTOS ===
          Static ram: 28380
          Dynamic ram: 96224 of which 0 recycled
          Exception stack ram used: 332
          Never used ram: 6136
          Task NETWORK ready, free stack 396
          Task HEAT blocked, free stack 1256
          Task MAIN running, free stack 3568
          Last reset 00:01:13 ago, cause: power up
          Last software reset at 2020-04-10 15:57, reason: User, spinning module GCodes, available RAM 6060 bytes (slot 2)
          Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0041f000, BFAR 0xe000ed38, SP 0xffffffff
          Error status: 0
          Free file entries: 10
          MCU temperature: min 19.7, current 20.1, max 20.1
          Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0
          Date/time: 2023-01-26 20:51:20
          Slowest loop: 9.78ms; fastest: 0.08ms
          Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
          Scheduled moves: 0, completed moves: 0
          Bed compensation in use: none
          Segments left: 0
          === Network ===
          Slowest loop: 201.94ms; fastest: 0.01ms
          HTTP sessions: 1 of 8
          === Filament sensors ===
          Extruder 0 sensor: position 0.00, ok, framing errors 0, parity errors 0, no calibration data
          M98 P"config.g"
          HTTP is enabled on port 80
          FTP is disabled
          TELNET is disabled
          • Phaedruxundefined Phaedrux moved this topic from Gcode meta commands
            It looks like the top half of the M122 results are missing.
            Can you send M115 to get the firmware version summary?
            • Flynbrdundefined
              Flynbrd @Phaedrux
              @Phaedrux yeah the spam filter kept me from posting all of it , let me try again,
              M115
              FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.0(RTOS) ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-06-05b3
              M122 part1
              Static ram: 28380
              Task NETWORK ready, free stack 324
              Last reset 00:02:19 ago, cause: power up
              Error status: 0
              MCU temperature: min 16.1, current 20.1, max 20.4
              Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0
              Date/time: 2023-01-26 22:13:08
              Slowest loop: 24.13ms; fastest: 0.07ms
                Phaedrux Moderator @Flynbrd
                @Flynbrd said in need help with config.g for cr touch and swiss drive:
                Your board is quite old and the firmware is from 2018.
                This would be a good time to update.
                If you still have access to DWC. Upload these zip files, one at a time in the system tab. Don't extract them first. Reboot after each. Use M115 in the gcode console to verify the firmware has been applied.
                https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet2and3Firmware-3.4.5.zip
                That will get your firmware and DWC up to date.
                You can see the change logs here:
                https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x
                For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
                https://configtool.reprapfirmware.org/Start
                Backup your existing config files in the sys folder in case you want to switch back to RRF2. It’s easy to switch back and forth, just upload the zip file for the version you want and then upload your config files.
                These documents will come in handy during the conversion.
                https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
                https://docs.duet3d.com/en/User_manual/RepRapFirmware/Migration_RRF2_to_RRF3
                https://docs.duet3d.com/en/User_manual/Reference/Gcodes
                Borgtribbleundefined 1 Reply Last reply Reply Quote 1
                • Borgtribbleundefined
                  Borgtribble @Phaedrux
                  @Phaedrux Thanks again, I didn't realize that the firmware had to be done in steps. I original ran the most current firnware weeks ago and called it a day. Last night I got it all updates done with no issue, now to work on the setting for the mc touch and direct extruder. Thank for all the info provided
                  Phaedruxundefined 1 Reply Last reply Reply Quote 1
                    Phaedrux Moderator @Borgtribble
                    @Borgtribble It depends where you start in the upgrade path. If you're already on 3.x it's a lot more straightforward. The order I've given just ensures you have all the files needed in case you want to go back and forth between versions at some point. I include 3.3 because the firmware folder was added in that release.
