    What to add next?
    • coffman34undefined
      coffman34
      I have successfully built my D-bot with a Duet Wifi and DeuX5. I have 3 independent Z motors, BLTouch, LEDs around the top for lighting.
      Currently finishing up printing ABS parts to replace the PLA parts I initially built with on a DaVinci Mini. I have noticed a 200% quality increase with using the parts printed from my D-Bot than from that DaVinci.
      I like to tinker, and add stuff, even if it's not necessarily needed.
      What are some of your Duet additions to your printers?
      I'm thinking a filament sensor using an endstop.
      Looking for other ideas, as I have a ton of open ports and such on my Duet and would love to start getting into the fun parts of this board.
      One day, when I build an enclosure I'll add some fans for the enclosure, and a temperature sensor on it as well. But that's going to be a little while down the line.
        IDEX perhaps?
        • deckingmanundefined
          deckingman
          3 or 5 colour mixing hot end (of you have a masochistic streak)? A few thermostatically controlled fans for cooling electronics or motors? RGB LEDs? Filament sensors?
          • adam2070undefined
            adam2070
            I am currently building a similar setup and working my configuration files at the moment. I am currently debating the following upgrades.
            • Dual Bowden Y-splitter setup for dual colour printing
            • LCD Display of some kind
            • Magnetic removable build platform.
            • Fillment sensors.
              coffman34
              @dc42:
              IDEX perhaps?
              IDEX Sounds interesting and complicated. I like it!
