Solved Local web address for 2nd duet mainboard
I just finished wiring up my 2nd duet mainboard. My existing printer is using the mainboard 6hc this one is just duet mini 5+
What will be the web address of my new printer. If the DWC is already duetlocal for the first one. Will I need to now use each printers IP address in the web browser now?
@Feynman137 use the M550 command in config.g to define the name of your new printer on the network. The name you specify will be converted to a MDNS name by converting it to lowercase and stripping out spaces and special characters, and truncating to 16 characters if necessary. For example, M550 P"Big Printer" would make the web address bigprinter.local.
Thank you!
