    Trouble connecting directly to Duet Ethernet via Desktop PC
    • tom_lauermanundefined
      tom_lauerman
      Re: How to connect directly to Duet Ethernet with Ethernet Cable?
      Hello all, I hate to revisit an old and boring topic, but I'm struggling mightily to connect directly to my Duet 2 Ethernet with an ethernet crossover cable going from the Duet right to the desktop.
      I installed YAT and went through the various posted steps. I have the following settings at the moment:
      Any help anyone might share would be greatly appreciated
      I had used the Duet wifi successfully for years but moved the printer to a location where I can't connect to wifi directly, so I am trying to switch to the Duet ethernet.
      gooberundefined 1 Reply Last reply Reply Quote 0
      • gooberundefined
        goober @tom_lauerman
        @tom_lauerman
        I believe you’ll need to use a standard cable not a crossover,
        Hope is of help
          Auto negotiation SHOULD work and a crossover cable is not needed. Have you tried yet with a normal cable?
          tom_lauermanundefined 1 Reply Last reply Reply Quote 0
            tom_lauerman @Phaedrux
            @Phaedrux I have not, will try that, thanks
              Also see here for a guide on wired direct connection: https://docs.duet3d.com/User_manual/Machine_configuration/Networking#wired-direct-connection
              tom_lauermanundefined 2 Replies Last reply Reply Quote 0
                @Phaedrux Thanks again, I hadn't seen that guide before, will dig into this
                  @Phaedrux many thanks all, I was able to get this up and running by following the guidance provided here. Cheers!
