    Mosquito Hotend PT1000 issues
    783
    • wcmartinoundefined
      wcmartino @dc42
      @dc42 Appoligies for the delayed response. I get the same results. I am good with running the nerw board on the Delta.
        dc42 administrators @wcmartino
        @wcmartino when and where did you purchase the original board?
        wcmartinoundefined 1 Reply Last reply Reply Quote 0
          wcmartino @dc42
          @dc42 I purchased the board from Fliastruder way back in Dec 2020.
            @wcmartino unfortunately it's out of warranty then. As the calibration process produces sensible L and H values, it appears that the ADC is working correctly. You could use your multimeter to check that the thermistor series resistors R60 R61 and R62 read correctly. They should each read 2200 ohms with nothing connected to the TEMP pins.
              wcmartino @dc42
              @dc42 No worries, I know it is too old. For now I have a new board installed and it is working good. I will mess with the other one when I have some free time. Thanks for all the assistance on this.
