    Duet Effector vs Piezo to eliminate Delta effector tilt?
    424
    • sniper23undefined
      sniper23
      Hello, everyone. After using BLtouch for years, I think it's time to switch to the less problematic z-probe solution. Effector tilt is a huge problem so I need a solution for eliminating that completely. I'm seeing that Smart Effector Duet claims to eliminate it but I can't buy it as it seems out of stock. But I can buy Precision Piezo but I don't know if it can eliminate effector tilt. I've searched the internet and couldn't find proper info about that as people seem to use XY or Cartesian Printers.
      Or I need a solution for BLtouch to eliminate tilt if possible.
        The piezo solution may help because it's still using the nozzle as the touch element, so no offset needed, same as with the smart effector.
        Where are you located? Where have you looked for stock?
        sniper23undefined tklnundefined 2 Replies Last reply Reply Quote 1
        • sniper23undefined
          sniper23 @Phaedrux
          @Phaedrux I'm in Turkey right now.
            You could try using M558 P0 to use the manual probing option where it asks you to jog the nozzle down to touch the bed. It's a bit tedious, but it would at least help you to verify that using a nozzle touch probe would solve your tilt issue.
            • tklnundefined
              tkln @Phaedrux
              @Phaedrux
              Does the smart effector also use pressure for the sensoring or does it use electrical contract?
                dc42 administrators @sniper23
                @sniper23 said in Duet Effector vs Piezo to eliminate Delta effector tilt?:
                There are plenty of Smart Effectors available, so if your usual reseller doesn't have any in stock, try another one.
                The Smart Effector detects nozzle force.
                  Phaedrux Moderator @tkln
                  @tkln It has a strain gauge built in to detect the pressure of nozzle contact.
                  • A Former User?
                    A Former User
                    This post is deleted!
