    Duet 3 mini 5+ wifi problem
    • Karimundefined
      Karim
      Hey guys I am have problems connecting to Wi-Fi . I set it up with YAT and was able to send M552 S1, which show connect to my net work. But once I disconnect the usb and put 24v I cannot connect to the duet through wifi. The blue light is on which I think it means wifi.
        Do you have a PanelDue?
        Can you gather a M122 when you are connected?
        Which LEDs are lit on the board?
        Karimundefined 1 Reply Last reply Reply Quote 0
        • Karimundefined
          Karim @Phaedrux
          @Phaedrux thank you, I got it working I replace the SD card.
