    Help!! Didn’t find access point while trying to connect
    Using Duet Controllers
    989
      Can you end M587 by itself and report back with what it says?
      Dillon Brownundefined 1 Reply Last reply Reply Quote 0
      • Dillon Brownundefined
        Dillon Brown @Phaedrux
        @Phaedrux
        M587: Failed to retrieve network list
        ok
        Error retrieving Wifi status message: bad reply format version
        Wifi module is idle
        wifi reported error: no known networks found
          Can you send M122 and copy and paste the full reply here?
            @Phaedrux trying to, but marked as spam
              Give it a minute and try again.
                @Phaedrux @Phaedrux sure:
                M122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
                Board ID: 08DGM-956GU-DGMSN-6J1F0-3S06P-KBQMG
                Used output buffers: 1 of 24 (1 max)
                Static ram: 25712
                Dynamic ram: 93216 of which 0 recycled
                Exception stack ram used: 304
                Never used ram: 11840
                Tasks: NETWORK(ready,1244) HEAT(blocked,1232) MAIN(running,3824) IDLE(ready,160)
                Owned mutexes:
                  Dillon Brown @Dillon Brown
                  @Dillon-Brown === Platform ===
                  Last reset 04:02:15 ago, cause: power up
                  Last software reset time unknown, reason: Heat task stuck, spinning module GCodes, available RAM 11484 bytes (slot 1)
                  Software reset code 0x00a3 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0043380f BFAR 0xe000ed38 SP 0x200049ac Task 0x4e49414d
                  Stack: 004486cf 0044a266 01001400 00000000 000004d9 00000000 00000000 3331bb4c 41880000 3e178897 3e1cd04f 3c0281fc 3e3a3325 3e638e29 3e924925 3885108c 397d66d2 c0a00000 00000000 60000010 0043db4f 00000062 0043b3bb
                  Error status: 0
                  Free file entries: 10
                  MCU temperature: min 19.4, current 33.1, max 33.4
                  Supply voltage: min 0.0, current 0.4, max 0.6, under voltage events: 0, over voltage events: 0, power good: no
                  Driver 0: ok, SG min/max not available
                  Driver 1: ok, SG min/max not available
                  Driver 2: ok, SG min/max not available
                  Driver 3: ok, SG min/max not available
                  Driver 4: ok, SG min/max not available
                  Slowest loop: 200.62ms; fastest: 0.05ms
                  Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
                  === DDARing ===
                  Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                  Segments left: 0
                  Movement lock held by null
                  http is idle in state(s) 0
                  telnet is idle in state(s) 0
                  file is idle in state(s) 0
                  serial is ready with "M122" in state(s) 0
                  aux is assembling a command in state(s) 0
                  daemon is idle in state(s) 0
                  queue is idle in state(s) 0
                  Code queue is empty.
                  === Network ===
                  Slowest loop: 8486.38ms; fastest: 0.00ms
                  HTTP sessions: 0 of 8
                  • WiFi -
                    Network state is running
                    WiFi module is idle
                    Failed messages: pending 0, notready 0, noresp 1
                    WiFi firmware version 1.23
                    WiFi MAC address 84:0d:8e:b2:15:56
                    WiFi Vcc 3.43, reset reason Hardware watchdog
                    WiFi flash size 4194304, free heap 23624
                    === Filament sensors ===
                    Extruder 0 sensor: no filament
                    ok
                    Can you send M997 S1 in the usb terminal? That will force a reflash of the wifi module.
                      @Phaedrux whats the usb terminal? Just the serial tools app ive been using to communicate?
                        @Dillon-Brown this is what i get back from M997 S1
                        M997 S1
                        Trying to connect at 230400 baud: success
                        Erasing 4096 bytes…
                        Erasing 212992 bytes…
                        Uploading file…
                        5% complete
                        10% complete
                        15% complete
                        20% complete
                        25% complete
                        30% complete
                        35% complete
                        40% complete
                        45% complete
                        50% complete
                        55% complete
                        60% complete
                        65% complete
                        70% complete
                        75% complete
                        80% complete
                        85% complete
                        90% complete
                        95% complete
                        Upload successful
                        ok
                          @Dillon-Brown I then tried M552 S1 and wifi went idle with no known networks found
                            @Dillon-Brown I may have to call spectrum and get them to direct away from my 5 ghz network again
                              Have you sent the M587 command to add your wifi SSID and password?
                              https://docs.duet3d.com/User_manual/Reference/Gcodes#m587-add-wifi-host-network-to-remembered-list-or-list-remembered-networks
                              And yes, it will only connect to a 2.4ghz access point.
