Error: short-to-ground reported by driver(s) 3
Seems i had a short in the wiring cable to the extruder and fried the duet wifi motor chip.
lots of smoke from the board and visible damage (burn damage to the chip)but it still is putting out console messages
Error: short-to-ground reported by driver(s) 3can i use the drive 4 E1 connector for driving the extruder again?
little afraid to just switch over .
but it should be possible to remap this?thanks
@DennisD yes, you should be ok doing that.
you may want to addM569 P3 R-1
to your config.g to disable reporting for the damaged driver
