    3.5.0-b2: Bed shut off during print
    Beta Firmware
    • CCS86undefined
      CCS86
      I just updated from beta1 to beta2 and ran a print job I have ran many times before.
      Everything started normally, the bed heated, probed, and began printing. But then shortly after I heard the noise of my prints coming loose and came back to find the bed at idle temp. No errors that I can see. It just turned off.
      Here is the console of that print and an M122 after cancelling it. Still not sure what happened:
      2/10/2023, 7:11:58 AM	m122
      RepRapFirmware for Duet 2 Maestro version 3.5beta2 (2023-02-08 17:43:40) running on Duet Maestro 1.0
      Board ID: 08DJM-956DU-LLMS4-7J9F6-3SN6Q-KBM2Q
      Used output buffers: 1 of 26 (26 max)
      Static ram: 22148
      Dynamic ram: 70368 of which 0 recycled
      Never used RAM 19268, free system stack 160 words
      Tasks: NETWORK(ready,51.0%,229) ACCEL(notifyWait,0.0%,349) HEAT(notifyWait,1.9%,336) Move(notifyWait,6.4%,308) TMC(notifyWait,17.1%,110) MAIN(running,22.9%,496) IDLE(ready,0.8%,31), total 100.0%
      Owned mutexes:
      Last reset 11:02:18 ago, cause: software
      Last software reset at 2023-01-28 08:45, reason: User, Gcodes spinning, available RAM 18740, slot 0
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x04
      Step timer max interval 1866
      MCU temperature: min 36.1, current 36.9, max 42.7
      Supply voltage: min 24.0, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/3, heap memory allocated/used/recyclable 2048/288/256, gc cycles 0
      Events: 0 queued, 0 completed
      Driver 0: standstill, read errors 0, write errors 1, ifcnt 67, reads 60499, writes 18, timeouts 0, DMA errors 0, CC errors 0
      Driver 1: standstill, read errors 0, write errors 1, ifcnt 67, reads 60499, writes 18, timeouts 0, DMA errors 0, CC errors 0
      Driver 2: standstill, read errors 0, write errors 1, ifcnt 68, reads 60498, writes 19, timeouts 0, DMA errors 0, CC errors 0
      Driver 3: standstill, read errors 0, write errors 1, ifcnt 41, reads 60505, writes 12, timeouts 0, DMA errors 0, CC errors 0
      Driver 4: standstill, read errors 0, write errors 1, ifcnt 13, reads 60511, writes 6, timeouts 0, DMA errors 0, CC errors 0
      Driver 5: not present
      Driver 6: not present
      Date/time: 2023-02-10 07:11:55
      Slowest loop: 1499.96ms; fastest: 0.16ms
      === Storage ===
      Free file entries: 10
      SD card 0 detected, interface speed: 10.0MBytes/sec
      SD card longest read time 2.5ms, write time 159.0ms, max retries 0
      DMs created 83, segments created 31, maxWait 5543437ms, bed compensation in use: mesh, comp offset 0.000
      no step interrupt scheduled
      === DDARing 0 ===
      Scheduled moves 145434, completed 145434, hiccups 25, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      Bed heaters 0 -1, chamber heaters -1 -1, ordering errs 0
      Heater 0 is on, I-accum = 0.2
      Heater 1 is on, I-accum = 0.5
      Movement locks held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Q0 segments left 0
      Code queue 0 is empty
      === Filament sensors ===
      Extruder 0 sensor: ok
      === Network ===
      Slowest loop: 1499.71ms; fastest: 0.02ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 1 of 8
      Interface state active, link 100Mbps full duplex
      2/9/2023, 10:40:49 PM	M0
      Cancelled printing file 0:/gcodes/Cold Plunge/Filter-Plug2 x12 315.gcode, print time was 0h 53m
      2/9/2023, 10:40:47 PM	Printing paused at X102.6 Y35.0 Z1.4
      2/9/2023, 10:40:44 PM	M25
      Resume state saved
      2/9/2023, 9:52:36 PM	225 points probed, min error -0.016, max error 0.066, mean 0.028, deviation 0.017
      Height map saved to file 0:/sys/heightmap.csv
      2/9/2023, 9:47:27 PM	M32 "0:/gcodes/Cold Plunge/Filter-Plug2 x12 315.gcode"
      File 0:/gcodes/Cold Plunge/Filter-Plug2 x12 315.gcode selected for printing
      • T3P3Tonyundefined
        T3P3Tony administrators @CCS86
        @CCS86 are there commands in the print file that could impact this? Is it repeatable, as in does it happen at the same point in a print?
        www.duet3d.com
        CCS86undefined 1 Reply Last reply Reply Quote 0
        • CCS86undefined
          CCS86 @T3P3Tony
          @T3P3Tony said in 3.5.0-b2: Bed shut off during print:
          I don't see any commands. No M140 or M190 after my start gcode.
          I'm running a quick test print right now and no issue so far.
          After it's done, I'll run the same print job that failed.
          • CCS86undefined
            CCS86
            The issue has not repeated. Hopefully, it was just a fluke.
            • CCS86undefined
              CCS86
              Well, after many successful prints, it just happened again.
              feet2.gcode
              edit:
              I may have just figured out the cause. If I select the file for print. Then, I cancel it, obviously it shuts off the heaters. Then I select "print again", it never reestablishes the bed heater. I have a conditional clause for my bed temp, that basically just asserts a longer dwell for stabilization if the bed was cold. But for either condition, it issues an M190.
                dc42 administrators @CCS86
                @CCS86 regarding this:
                if heat.heaters[0].current < 60-1
                	M190 R60                                ; Wait for cold bed
                	G4 S240                                 ; Cold Pause
                else M190 R60                               ; Wait for hot bed      <<<<<<<
                	G4 S1                                  ; Hot Pause
                The M190 command with the "Wait for hot bed" comment wil be ignored because it needs to be on a separate line, not on the same line as the 'else'. I will change the parser to generate an error message when there are unexpected characters after 'else'.
                CCS86undefined 1 Reply Last reply Reply Quote 2
                • CCS86undefined
                  CCS86 @dc42
                  @dc42 said in 3.5.0-b2: Bed shut off during print:
                  	G4 S1                                  ; Hot Pause
                  Great, thank you for that correction!
