Problems after upgrading to Dyze Horizon RRF 3.4.5
Hello Everyone,
Some years back I built a Railcore II 300ZL, and it has been a great printer humming along printing stuff for years. I recently bought a Dyze Horizon load cell for using the nozzle for bed leveling instead of the bl touch. I had to upgrade to the latest 3.4.5 Duet firmware from 2.x firmware to get it to work. It has been a long time since I set up the config.g and I am lost with all the changes in the firmware. Could you folks help me out getting this straightened out? my config.g is below- No voltage at the always on fan terminals for the hemera extruder fan on the Duet.
- When I hit the macro "test fans" I get nothing from either fan- extruder or part cooling fan.
- The PID tuning for my revo hotend just seems to trail off at stage 3 or 4.
Thanks in advance.
Regards, Matt; Configuration file for My Printer
; Communication and general
M111 S0 ; Debug off
M550 PRailCore ; Machine name and Netbios name (can be anything you like)
;M551 Pmyrap ; Machine password (used for FTP);*** Wifi Networking
M552 S1 ; Enable WiFi
M555 P2 ; Set output to look like Marlin
M575 P1 B57600 S1 ; Comms parameters for PanelDueG21 ; Work in millimetres
M83 ; ...but relative extruder moves; Axis and motor configuration
M669 K1 ; RRF3 change M667 to M669 ; set CoreXY modeM584 X0 Y1 Z5:6:7 E3:4:8:9 ; Map Z to drivers 5, 6, 7. Define unused drivers 3,4,8 and 9 as extruders
M569 P0 S0 ; Drive 0 goes forwards (change to S0 to reverse it) X stepper (Rear)
M569 P1 S1 ; Drive 1 goes backwards Y Stepper (Front)
M569 P2 S1 ; Drive 2 goes forwards Unused
M569 P3 S0 ; Drive 3 goes forwards Extruder
M569 P4 S1 ; Drive 4 goes forwards Extruder (unused)
M569 P5 S0 ; Drive 5 goes backwards Front Left Z
M569 P6 S0 ; Drive 6 goes backwards Rear Left Z
M569 P7 S0 ; Drive 7 goes backwards Right Z;Leadscrew locations
M671 X-10:-10:333 Y22.5:277.5:150 S7.5 ;Front left, Rear Left, Right S7.5 is the max correction - measure your own offsets, to the bolt for the yoke of each leadscrewM350 X16 Y16 Z16 E16 I1 ; set 16x microstepping for axes& extruder, with interpolation
;RRF3 comment out: M574 X1 Y1 Z0 S1
M574 X1 S1 P"xstop" ; RRF3 set X endstop to xstop port active high
M574 Y1 S1 P"ystop" ; RRF3 set Y endstop to ystop port active high
M574 Z1 S2 P"!zstop"
M906 X1400 Y1400 Z1000 E800 I60 ; Set motor currents (mA)
M201 X3000 Y3000 Z100 E1500 ; Accelerations (mm/s^2)
M203 X24000 Y24000 Z900 E3600 ; Maximum speeds (mm/min)
M566 X1000 Y1000 Z100 E1500 ; Maximum jerk speeds mm/minute
M208 X280 Y280 Z280 ; set axis maxima and high homing switch positions (adjust to suit your machine)
M208 X0 Y0 Z-0.5 S1 ; set axis minima and low homing switch positions (adjust to make X=0 and Y=0 the edges of the bed)
M92 X200 Y200 Z1600 E837 ; steps/mm; Thermistors
;RRF3 comment out: M305 P0 T100000 B3950 R4700 H0 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
M308 S0 P"bedtemp" Y"thermistor" A"bed_heat" T100000 B3950 R4700 H0 L0 ;RRF3 Bed thermistor, connected to bedtemp on Duet2;If you have a Slice Engineering thermistor, comment out the next line
;RRF3 comment out: M305 P1 T100000 B4725 R4700 H0 L0 C7.06e-8 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
M308 S1 P"e0temp" Y"thermistor" A"e0_heat" T100000 B4725 R4700 C7.06e-8 H0 L0 ;RRF3 duet3 e3d;If you have a Slice Engineering thermistor, uncomment the next lines. KITS DO NOT SHIP WITH A SLICE THERMISTOR - ONLY UNCOMMENT IF YOU ORDERED ONE
;M308 S1 P"e0temp" Y"thermistor" A"e0_heat" T500000 B4723 R4700 C1.196220e-7 ;RRF3 slice thermistorM950 H0 C"bedheat" T0 ;RRF3 define Bed heater is on bedheat
M950 H1 C"e0heat" T1 ;RRF3 define Hotend heater is on e0heat
M140 H0 ; bed heater 0 uses heater 0M307 H0 A240.3 C608.7 D8.2 S1.00 V24.1 B0 ; Bed Heaters
M307 H1 A270.7 C90.4 D6.7 B0 S1.0 ;Heater 1 model
M570 S360 ; Hot end may be a little slow to heat up so allow it 180 seconds
M143 S285; Fans
M950 F0 C"fan0" ;RRF3 define fan0
M950 F1 C"fan1" ;RRF3 define fan1
M950 F2 C"fan2" ;RRF3 define fan2
M106 P0 H-1 ; disable thermostatic mode for fan 0
M106 P1 H-1 ; disable thermostatic mode for fan 1
M106 P2 H-1
M106 P0 S0 ; turn off fans
M106 P1 S0
M106 P2 S0; Tool definitions
M563 P0 D0 H1 ; Define tool 0
G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
;*** If you have a single-nozzle build, comment the next 2 lines
;M563 P1 D1 H2 ; Define tool 1
;G10 P1 S0 R0 X0 Y17 ; Set tool 1 operating and standby temperatures; Z probe and compensation definition
;*** If you have a switch instead of an IR probe, change P1 to P4 in the following M558 command
; IR PRobe - uncomment the following 2 lines if you have a and IR Probe, and comment out the BLTouch section below
;RRF3 IR Probe only comment out: M558 P1 X0 Y0 Z1 ; Z probe is an IR probe and is not used for homing any axes
M558 P5 C"!zstop" ; RRF3 IR Probe connected to Z probe IN pin
G31 X0 Y30 Z1 P500 ; Set the zprobe height and threshold (put your own values here);BLTouch - comment out the following 3 lines if using a IR Probe
;RRF3 comment out: M307 H3 A-1 C-1 D-1
;RRF3 comment out: M558 P9 X0 Y0 Z1 H5 F50 T6000 A5 S0.02
;M558 P5 C"!zstop" H1 H5 R1 F50 T6000 A5 S0.02 ; RRF3 BLTouch connected to Z probe IN pin
;M950 S0 C"duex.pwm1" ; RRF3 Define BLTouch Servo (S0) on duet pwm1
;G31 X2 Y42 Z2.65 P25 ; Customize your offsets appropriately - do a paper test, and put the probed value in the Z value hereT0 ; select first hot end
image url))
Can you send M122 and M98 P"config.g" and copy and paste the results here?
@Phaedrux
Hi Phaedrux,
Thank youM98 P"config.g"
Error: Invalid use of P parameter
Warning: Heater 0 predicted maximum temperature at full power is 265°C
Error: in file macro line 62: M570: missing parameter 'H'M22 P"config.g"
Error: M22: expected number after 'P' -
Sorry for the confusion, these are two separate commands.
M122
which will give you a diagnostic reportM98 P"config.g"
which will run config.g and throw out any error messages that may get missed during startup.@mattmullen said in Problems after upgrading to Dyze Horizon RRF 3.4.5:
one of the error messages it caught was that this command is missing the H parameter to tell it which heater you're referring to. So currently that command isn't having any effect.
@Phaedrux
Hi Phaedrux,
Thanks again for your help,
the M122 results are below:2/11/2023, 2:09:14 PM m122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.5 (2022-11-30 19:36:12) running on Duet WiFi 1.02 or later + DueX5
Board ID: 08DLM-996RU-N8PS0-7JKD6-3S86Q-TA8BN
Used output buffers: 1 of 26 (15 max)
Static ram: 23836
Dynamic ram: 75720 of which 60 recycled
Never used RAM 12392, free system stack 152 words
Tasks: NETWORK(ready,15.0%,242) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,312) DUEX(notifyWait,0.0%,24) MAIN(running,84.6%,440) IDLE(ready,0.3%,30), total 100.0%
Owned mutexes: WiFi(NETWORK)
Last reset 00:03:48 ago, cause: power up
Last software reset at 2023-02-10 12:56, reason: User, GCodes spinning, available RAM 12832, slot 0
Error status: 0x00
Aux0 errors 0,0,0
Step timer max interval 0
MCU temperature: min 17.7, current 26.2, max 26.4
Supply voltage: min 24.0, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
Events: 0 queued, 0 completed
Driver 0: standstill, SG min n/a
Driver 1: standstill, SG min n/a
Driver 2: standstill, SG min n/a
Driver 3: standstill, SG min n/a
Driver 4: standstill, SG min n/a
Driver 5: standstill, SG min 0
Driver 6: standstill, SG min 0
Driver 7: standstill, SG min 0
Driver 8: standstill, SG min n/a
Driver 9: standstill, SG min n/a
Driver 10:
Driver 11:
Date/time: 2023-02-11 14:09:11
Slowest loop: 8.03ms; fastest: 0.18ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.6ms, write time 0.0ms, max retries 0
DMs created 83, segments created 3, maxWait 22795ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
Scheduled moves 2, completed 2, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1
=== AuxDDARing ===
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty
=== DueX ===
Read count 1, 0.26 reads/min
=== Network ===
Slowest loop: 12.56ms; fastest: 0.00ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
HTTP sessions: 1 of 8
= WiFi =
Network state is active
WiFi firmware version 1.27
WiFi MAC address ec:fa:bc:5b:3c:34
WiFi Vcc 3.38, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 20432
WiFi IP address 10.0.0.58
WiFi signal strength -32dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
Socket states: 0 0 0 0 0 0 0 0 -
I had a blown fuse for the fans, so that problem is solved but I still have an issue with the PID tuning. It just trails off and the hotend cools down. Anybody have any ideas?
When you say trail off, what do you mean? Do you get an error message?
What tuning command did you use?
@Phaedrux
I used M303 T0 S205 the hot end is an E3D Revo.
It will go through stage 3 or 4 and then cool down to room temp without returning the tuning numbers. No error messages. -
Can you try tuning with
M303 H1 S205
instead?
