Duet2 wifi cs0 pin
Hello.
I am trying to connect accelerometer to conn_sd socket (I do already have CS1 upto CS4 in use). Looks like all necessary pins are there but spi_cs0 isn't listed as Duet2 pin name. Does this pin name is different or we just can't use cs0 at all? -
@Buhefade cs0 is reserved for the PanelDue SD card. If you don't have a DueX connected, you can use one of the additional endstop inputs on the expansion connector for the accelerometer CS pin.
