Endstop indicator on Y axis not working in DWC 3.5b2+1
A trivial thing, but for me the little green status indicator is only working on the X axis.
End stop is definitely working.Board: Duet 2 WiFi (2WiFi)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.5beta2+ (2023-02-11)
Duet WiFi Server Version: 2.1beta3
Duet Web Control 3.5.0-beta.2+1M208 X0:215 Y-2:200 Z0:180
@OwenD It's working for me (Z also works) with nearly the same setup; 3.5beta2+, but build date is different:
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.5beta2+ (2023-02-10)
@droftarts said in Endstop indicator on Y axis not working in DWC 3.5b2+1:
@OwenD It's working for me (Z also >works) with nearly the same setup; >3.5beta2+, but build date is different:
I built from source which explains why my build date is a day later.
There appears to be something really weird with my end stop.
I just ran multiple home Y moves and occasionally the indicator works.
Can only assume that somehow it's triggering then breaking contact??
I'll mark this as solved. -
