Broken belt
I need 4m, in 1 piece… I already checked, and I never found a closed belt > 1m70. So, even if I use 2 belts, it is not enough.
I'm in France.
Hmm, I see that the French misumi website doesn't even list the MR3 belt (Misumi uses the number to indicate belt pitch, unlike gates… confusingly).
Perhaps you should buy several types of cheap belt from China, then you can choose the one that looks the best (You should be able to visually see the fiber core from the side or the cut ends).
Pick the one that looks like it was cut the straightest, has no defects in the surface, has the most tensile members, etc.
Yes, GT3, 3GT GT 3MR… What a mess! In fact, I'm using old Stratasys parts, which where using GT (first gen, I guess). The Stratasys belts (Gates) are good, even after years.
I'm waiting for Tanals answer, as they sell PowerGrip(R) GT and GT3.
Well, it sounds like if there are belts to be had in France, you will find them. Good luck!
Pfff, they don't want to sell to individuals Then they complain we buy in china… It puzzles me.
